Problem with HP F4280 DeskJet All In One Printer InkJet
When someone installed my F4280 deskjet program onto my computer, they put the language settings to Chinese, I need to know how to change it back to English
Posted by avatar on Jan 24, 2011
Suggested Solution (3)
I seem to have lost my installation cd for the HP deskjet F4280 all in one printer. I just had my computer re-formatted and need to install the printer. Can you help
  • by Author image r_ezany Over a year ago
Source: I lost me installation cd for my HP deskjet F4280
Was this solution helpful?
No
Yes
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
  • by Author image Nikhil Gedam Over a year ago
    • By avatarjimbeb Mar 25, 2011
    • 03-24-2011 07:54 AM Just had the same problem. Dispaly in German after selecting English-Europe. Hp support had no answer after 25 mins on the phone. Finally solved it myself. This is for a Deskjet 3050 1) Remove power cord. 2) Press and hold together Cancel button and OK button ( OK button is the one at the very bottom). 3) Reinsert power cord to rear of printer while holding in both of these buttons for about 20-30 seconds. 4) The HP sign should come onto the dispaly. This should reset the dispaly screen back to factory settings. You will have to reconnect your wifi again. This worked for me. Good luck.
Source: How to reset Language
No
Yes
Sure. But it will require you to uninstall the software you are using currently and installing the english version. If you do not have the CD or the software, you can use this link to download the driver software in English. Click on any of these links. the second one takes you straight to downloading the file. Its the complete package, about 311MB.
  1. HP Officejet Pro Full Feature Software And Driver.
  2. OJProL7X00_Full_8_3.exe, (1/1 , 311.3M)
  • by Author image Nathaniel Iwuchukwu Over a year ago
Source: Can you change the language on the HP Photosmart essential?
No
Yes
Tips for Helping julianaweiwa With Their Issue
  • Give detailed step-by-step instructions
  • A picture or video is helpful
  • Use plain language not industry jargon
  • Check spelling & punctuation
Hide Tips
Add Your Solution
See all HP F4280 DeskJet All In One Printer InkJet Problems
