Question about Maytag M6Q10F2A Air Conditioner
Maytag on the out
The unit will stop running and EE will appear
Our maytag window air conditioner (12,000 BTU; model#M^Y12FB-J
changes the temperature on its own. And it always goes up in temperature as high as 88 degrees and of course then it isn't cooling at all. I checked to see if frost or ice had collected on the copper tubing but it hasn't. I unplugged it for 1 hour to see if it would reset but that didn't help. It is about 2 years old. When it first happened, it seemed that if I used the remote it would stay at the right temp., but now it doesn't matter. It's hot and humid in my house - help!
Susie
Posted on Jul 25, 2008
Flashing EE:EE on airconditioner wall control
your system might need reseting look for a reset switch on your thermostat or your inside unit usually means dirty filter
Jan 04, 2013 | Heating & Cooling
Repair of room air conditioner /window unit
You need to check the main breakers in the breaker panel......
Sep 01, 2008 | Heating & Cooling
I get a EE code on the display. What is it?
Hello
EE is a high pressure error code. The unit may be to small for the room deppending on what temp it is outside.If its over 95.f The a/c is probably overworked.
One way to solve this would be to cool down the coils outside.Spray water lightly on the outside of the unit too cool it down which will bring the pressure down also.
Jul 20, 2011 | Maytag M6W12W7A Air Conditioner
The Maytag a/c unit model #M6Q10F2A has been working fine until this morning. The display reads "EE" and the a/c does not work. Unplugging the unit does not help.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Maytag M6Q10F2A Air Conditioner
My air conditioner turned itself off and now the display reads EE we have unplugged it it runs for a little while then shuts itself off again
Remove the unit from the window,and dissassemble and use a water hose and clean the inside of the unit,remove all debris,this is most likely the problem.
Jul 10, 2010 | Maytag M7Y15F2A Air Conditioner
Maytag EE Error
I can't let you know, It will be $9.99 for the info.
Jul 27, 2008 | Maytag M6Q10F2A Air Conditioner
Maytag error message EE
What is the name and model number of your unit?
Jun 10, 2008 | Maytag M6Q10F2A Air Conditioner
EE in the display window
Hi, I have been trying to get in touch with a service rep to find out but unable to get one. They wanted proof that I had purchased a unit. Its possible that your receptacle is not polarized right. By that I mean the two wires may need switched on the receptacle or maybe it doesn't have a good ground. You may want to try temporarily using an extension cord and try another plug. Most things will run good on receptacles wired wrong but with a computerized AC it may be seeing a fault. If you still need help I think the best way to find out would be for you too contact the store that you bought the unit from and make it their responsibility to find out what the EE stands for. If they cant, get the unit replaced and try again. If you do get hold of a service tech # from Maytag, please send it to me at kstfas@yahoo.com Hope this helps. kstfas
Aug 27, 2007 | Maytag M7Y10F2A Air Conditioner
EE IN TEMP DISPLAY
I just called a maytag repair store, and they just had one in the shop, it sounds like the control panel has died, and will need to be replaced. They cost around 60 dollars, + install fee.
Jul 05, 2007 | Maytag M6Q10F2A Air Conditioner
Maytag M6Q10F2A Air Conditioner Logo
119 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
