Question about Achiever CCS5000 Shredder
CCS5000 Shredder the shredder makes a loud squeaky noise
  • 57 Answers
Have you had a maintenance work done to this machine lately.
You gears may be dry. This could damage your blade.It could also be the gear. Have tech look at it. or if you closed to the jersey area I can recommend a tech. I can not walk you through this because it is a big machine and better to be operated by train tech.
Good luck
let me know
Posted on Jul 23, 2008
Our Achiever CCS5000 worked well until it was
Hi Alan,'
it is not available, you could find the interlock switch and jump them...cut wires off of switch and twist together, then use electrical tape.
Mar 03, 2010 | Achiever CCS5000 Shredder
I need a fuse for my ccs5000 achiever shredder. Do you know where one can be purchased?
Radio shack has a good selection. Make sure you match it exactly. Do not put a larger capacity fuse in there. It can burn the circuit board.
Jun 18, 2009 | Achiever CCS5000 Shredder
Acheiver CCS5000 screaching noise
A piece of metal or coin might have gone into the shredder.
Apr 22, 2009 | Achiever CCS5000 Shredder
Shredder sounds like dry rubbing when in use.
No do not use WD-40.
They make shredder lube. It is a thick silicon type oil. I would just google shredder lube and I'am sure you will find what you need.
Good Luck
Andrew
Mar 16, 2009 | Achiever CCS5000 Shredder
Squealing Shredder
you need to spray lubricant down the paper shout. the cutter wheels are dry. They make a shredder oil but you don't need that just a light what oil. wd40 is to heave. If the noise is still there then it is in the gear train and will need to br serviced.
but to much oil will make a build up of dust also it's a catchy 22
Nov 03, 2008 | Achiever CCS5000 Shredder
I need a manual for my shredder
the overload beeper want cut off and there no paper in it
Aug 27, 2008 | Achiever CCS5000 Shredder
Loud grinding noise when the shredder is on.
Your gears may be stripped - mine were. Time to get a new shredder
Jul 09, 2008 | Tech Solution TS-8000 Cross-Cut Shredder
Achiever Shredder CCS5000
Is it on a 20 amp circuit? Check to make sure that it doesn't have a grounding problem or even the plug could be reverse woired.
Oct 10, 2007 | Achiever CCS5000 Shredder
Noisey Shredder
Have you oiled the blades? When was the last time it was serviced? There is an awful lot of paper shredds inside the unit. Motor bearings need lubrication. Gears need grease, etc. Put about a dozen drops of light oil directly down into the cutter left to right every half inch. I have used vegetable oil in a pinch.
Feb 01, 2007 | Achiever CCS5000 Shredder
Achiever CCS5000 Shredder Logo
106 people viewed this question
Top Achiever Office Equipment & Supplies Experts
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
