If horrible sound is while drainpump is draining but before washer starts to spin either obstruction in drain pump or impellar on pump is bad and the complete pump needs replaced... if noise is while spinning the spider support is cracked which is very exstensive repair and dont reccomend repairing unless you have a couple of hours for dissasembley and reassembley...
SOURCE: washer makes clicking noise when tub rotates
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995522231.pdf here is apart break down of your unit. if you scroll down to pg 10 you see the inner baket assy, chances are youve snapped parts(14)which screw into (15). perhaps you found a broken screwhead inside the tub after laundry was done? id remove the agitator screw down the shaft and it will be quite apparent
SOURCE: Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
SOURCE: washer is making a grinding sound when draining water.
hi, this grinding sound is coming from the pump. the pump device seems to have a broken impeller that is located inside the pump. You will not be able to replace this internal part. This device is fixed and you will have to replace the entire pump assembly.
This will happen if some debris or coins make it threw the pump housing. these debris will settle in the pump housing near the impeller and it will grind while in operation or, draining procedure. the solid debris will eventually damage the impeller and break it off the drive bolt. this will all happen in time but, it usually starts with the minor grinding sound.
SOURCE: washer wont drain or spin out water, leaves water in the tub
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: washer makes straining noise when draining water f...
my admiral washer machine model AAV7000AWW makes a noise only when draining/spining water, is no water spill at all. Thanks
