Question about PC Chips P23G Motherboard
P23g PC Chip Mother Board and DDR2 Ram
I just buy 2 DRR2 533mhz 1G memory RAM to upgrade my PC, I have a P23G PC chip, and when i boot into windows XP it start giving problem of loose files on the Win start up and then reboot, I get back to my all setup , 2 DDR 400 of 512MB and the windows works OK. Any advice about this.
Also, the bios does reconize the new memory and also set the speed to 533 when it start.
I will be very tankfull of any advice on this
  • Doblelock Jul 18, 2008
    I've check that already and the BIOS was in auto, as i said, it does recognize the memory when i boot with the new ram it change to 533
  • jose guadalu Oct 28, 2008
    i need drivers
  • 781 Answers
Probably your motherboard does not recognise the faster ram go to BIOS setup and check ram is set for auto
Posted on Jul 18, 2008
What ram does a pcchips take ddr2 slot's being used combine with Pentium d and a 6600 gt
Thanks for posting your question. This took me a ton of time to find. Please leave me a great rating on this answer for finding the solution.
DDR400+DDR2 533 Supports Single-channel DDR2 533/400 DIMM and Single-channel DDR400/333 DIMM. Users can use either DDR2 or DDR memory modules.
Again, please leave me a great rating on this answer so others may benefit from this solution too!
Sep 24, 2011 | PC Chips P23G Motherboard
Make sure it is the correct ram for your computer. If you just added one ram chip then try swapping them and make sure they have a tight fit.
To test the new chip replace the old one with it and turn on your machine. If it doesn't see it then it is either bad or not the correct one.
Let me know how it goes.
Dec 14, 2010 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
I have bought a kingston DDR2 ram memory (800 mhz, PC6400, 2GB = 1x2GB) and my motherboard recognizes only a half of it (1024). What can I do to fix it?
If its one RAM den be sure it is 2 GB if 2 RAMS den please see that have you fixed the RAM properly..Try taking out the RAM and clean the lower portion with a clean Rubber/Eraser and dne fix it back properly..
Mar 27, 2010 | PC Chips P23G Motherboard
BIOS only seeing half of just-installed 2x1GB DDR2 RAM
did u check the old they also show only half ?
may be ur new RAMs are not compatible with ur MB
what's the speed of ur new RAMs....400 or 533 ?
Jan 05, 2010 | PC Chips P23G Motherboard
You have 4 memory slots on this MB. 2 are for DDR 400 and 2 for DDR2 533. Maximum supported memory is 2GB. As to installation, press the tabs to raise the memory stick out of the socket and replace with the new ram. Just push down till it locks in place.
Here is a link.
Nov 28, 2009 | PC Chips P23G Motherboard
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
Pentium D 1066 extreme processor install.
What version is your board. PC Chips P23G V1.0 up to V3.0 ?
Apr 24, 2008 | PC Chips P23G Motherboard
Ram DDR2
Hi Terry, you're board, PC Chips P23G only supports a max memory of 2GB. Please check pg. 9 of your manual, Installing Memory Modules.
Please be noted you can NOT use DIMM DDRII 1~2 (DDR2 533/400) and DIMM DDR1~2 (DDR 400/333) simultaneously. Only use either DDR2(533/400) or DDR(400/333) memory modules! (You should check the spec's of the other board before inserting memory that may not be supported). (You can damage the memory)
Click the link listed below for you're PC Chips P23G board.
Suggest you save this link to you're favorites.
You will notice there is a fix for:
Patch code to fix REALTEK clock buffer sometimes couldn't detect DDR2.
Once there, click BIOS. Scrol down to the bottom of the page & read special notes. Than click the drop down menu & pick a download site. Creat a folder on you're desktop to store the download. Uncompress the .zip file. You will than have a folder named 070115 & a ROM file named 070115.ROM
This bios flash program requires you to use a floppy disk drive to flash the bios.
Follow the instruction at this link to flash you're bios.
If you find to hard to folow you can pick another from this google search site.
Good Luck! & Take your time.
Have more questions, feel free to ask.
How to vote you're expert.
Enter site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 12, 2008 | PC Chips P23G Motherboard
Upgrade problems
The p23g V1.0 motherboard doesn't support the core duo processor. Do not try to install it or you may damage either the board or the processor.
The p23g V3.0 support also the core duo processor
Follow this link and you can see for each motherboard the different processor used.
My suggestion is that you use the p29g
Oct 21, 2007 | PC Chips P23G Motherboard
PC Chips P23G Motherboard Logo
675 people viewed this question
Top PC Chips Computers & Internet Experts
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
