Question about Microsoft Xbox 360 Console
X box over heating
Runs for about 10 - 15 minuts then quits as if it is over heated
    Scholar:
  • 154 Answers
You may have a software failure when mine did that it worked for a while shut down and then you had to restart it after a minute or so and sometimes it turned on straight away again after about a week of this it got 3 red lights the ring of death or software failure send it to microsoft and get fixed
Posted on Jul 23, 2008
Heater runs for 2-3 minutes then quits
Either the unit is over heating and being thermally shut down or the temp shutdown switch is shutting down prematurely.
Jan 01, 2016 | Heating & Cooling
Dryer heats up for a few minutes and then quits but dryer still runs
Hello
When the dryer heats for few minutes and then it won't work it means that the thermal fuse is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this fuse for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Nov 17, 2010 | Speed Queen AES28AWF Electric Dryer
My dryer heats up but doesn't run the full time set on the timer - basically overheats - I have to let it cool down (usually 60-90 minutes I can use it again)
It sounds like your relay switch has stopped functioning. You will find it at the front of the machine beside the control panel. Its encased in a brown perspex box and is quite easy to replace.
May 24, 2010 | Amana Dryers
It quits heating after a couple minutes and sounds
replace the fan otherwise your microwave cell wil burn out, the safety comes on because the cell become to hot. no colling of microwave cell.
Feb 15, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Dryer Heats for 30 Minutes then stops heating
Hello there :
what you are going to want to do is to troubleshoot the heating circuit
if you have a multimeter
there is a thermal Cut-Out switch that is connected to the heater box.) -simply unplug wires and take reading from the end connetors
your reading should be 0 ohms. and nothing else
Next check
a part called the Hi-Limit Thermostat that is connected to the heater box, it should be located closest to the heating element wire leads unplug the wires and take the reading across the 2 wire connections . this should give you a reading of 0 ohms and nothing else.
Now if any of these 2 parts are not in this range they need to be replaced and i would recommend that you replace them as a set cause if one usually goes out then the other one will soon follow ok
I hope this is very helpful for you
Best regards Michael
Jan 09, 2010 | Kenmore Dryers
Heated and cooled seats quit working. won't work on either driver's or passanger's seats. checked the fuses and relays and they are all ok. what's wrong?
Remove fuses 10 and 11 in the underhood junction box. Leave out for 5 minutes then reinstall. If the seats start working your Zephyrs dual climate control seat module will need replaced.
Apr 23, 2009 | 2006 Lincoln Zephyr
Pump is running ever 5 minutes. The heat in the
Sounds as if the 'mode' for the tub is set to sense the temperature of the water. see if there is a setting on the control box to a 'timed' setting for filtering and heating instead of controlled by the temperature setting. the problem is the the control box is away from the water and when it calls for heat it is because the water is cooler there than in the hot tub. so when it calls for heat and the water starts to circulate it gets the hot water from the body of the hot tub and then shut down because it senses the 'hot water'. make sense?
Feb 23, 2009 | Blue Wave Aruba 15' Round 54" Resin Pool...
Heating Problem
If this is a gas dryer, you probably have bad valve coils, they can work intermittently, usually for the first part of a cycle, but when they heat up the internal resistance gets too high and they fail to open the gas valve. Once they cool off, (by continuing to air dry) they will work again for a few minutes. They will also make a buzzing/rattling (maybe "metal" ) noise as voltage is applied. For any Kenmore gas dryer, get part #279834 it contains both valve coils. Very easy to replace. Another possibility is that your duct work is plugged, check airflow. Hope this helps.
Sep 14, 2008 | Kenmore Dryers
Quits heating
umm. what was original problem that made you change coils to begin?? no heat i would imagine.dont rush to judgement thatyour fix didnt work, if your running the dryer empty to test your repair,its quite possible that the dryer is going to heat to desired temp quickly, and take a while to cycle back on. throwsome wet clothes in machine and test it then.
Mar 05, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Microsoft Xbox 360 Console Logo
16 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
