Question about DISH Network IR Remote Control
I would like to program my dish network remote control on my tv apex
  • 36 Answers
You can use the following link to find the codes for your Apex tv.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Just click the remote codes in Step 1 to get to the list.
That main link will also provide the step by step instructions to program it.
Nick Franta
DISH Network Customer Service
Posted on Jan 24, 2011
SOURCE:
Trying to set DISH remote for an APEX LD4088. need the code please
Hello chiech22,
I noticed your post and see that your DISH remote needs to be programmed to your APEX TV. There are a couple of ways that your remote can be programmed to your TV. One option would be to use the remote code that is for your TV, these codes may vary depending on the model of your remote. The best option for you would be a Power Scan to get your remote programmed to your TV. Here are the steps.
1- While at the TV locations (TV1 or TV2 depending on which key is installed), point the remote at the TV. Press and hold the TV MODE button on the remote until all four MODE buttons at the top of the remote light up.
2- Press the RECEIVER POWER button on the remote.
3- Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the TV turns off. This process may take several minutes.
4- Press POUND (#) on the remote. The TV MODE button will flash three times.
5- Press TV POWER on the remote to turn on the TV. Press VOLUME on the remote to confirm the remote controls the TV. If this does not work, return to Step 1.
If you need any further assistance let us know. I hope this helps.
Jul 24, 2011 | DISH Network IR Remote Control
How to i program a direct tv remote to my digital tv converter. dt250 model apex
nucklebuster
I have provided a link with instructions on how to program yoru remote to your TV. The Webpage also has links for the codes. I hope this helps.
http://2getdtv.com/directv/remote_codes.html
Ray Calo
DISH Network
Mar 23, 2011 | DISH Network IR Remote Control
Trying to set up dish network remot to apex dvd player
dr172120,
I'm sorry you are having problems programming your DISH Network remote to your Apex DVD player. I looked through our remote codes but I don't show we have a code for an Apex DVD player. We do have remote codes for an Apex TV. You can run a power scan to see if you can find a code for the DVD player. I have provided the instructions to conduct the power scan below. If you have any other question, please post to this site.
Ray Calo
DISH Network - Executive Offices
Address To Other Equipment Using Power Scan
  • Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
    2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
      Then Press STAR (*)
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Jan 14, 2011 | DISH Network IR Remote Control
Need code for apex tv
Hello, Tommy Faust with DISH Network here. I'd be happy to help you get those codes.
The main codes we have for an Apex tv are 595, 744, 743. Hope one of these codes helps you! Feel free to post here if you have any other questions!
Dec 02, 2010 | DISH Network IR Remote Control
I have an apex tv but can't get the dish network remote code to work
Hello! Sometimes the remotes have trouble programming to the tv. But follow the simple steps by following the link below to run a scan on your remote to get the correct code so that it will work the tv. Hope it helps.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
Nov 27, 2010 | Apex Digital LD3249 LCD TV
I have ( Apex digital LD4688 ) I neeed the code. Thank you.
I install dish network. i have tried all versions of dish remotes, . the only one that works is Dish Network 21.0 Learning Remote. it will work with all dish products and i have programed it for this tv apex ld4688 hd and it works great.here is a link for the manual on how to use.
http://www.satelliteguys.us/dish-network-forum/158496-dish-network-21-0-learning-remote.html
Nov 27, 2010 | DISH Network IR Remote Control
Need the code for apex 46 in. 1080p lcd tv for dish remote
Hello, my name is Tommy Faust with DISH Network. I would be pleased to help you with that.
The main codes for a Apex tv are 595, 744, and 743. Give those a try and see if they work. Feel free to ask here if you have any other questions/concerns!
Nov 26, 2010 | DISH Network IR Remote Control
I need a code to program my Dish network remote control to my APEX AT2002S TV please
Hello!! All you need to do is follow the link that I provided below. That will walk you through a power scan, where the remote scans the codes on the tv, until it reaches the right one. It is simple and quick!!!
Becki Barned
Aug 24, 2010 | Apex Digital AT2002S 20" TV
Dish network: need codes fof APEX tv ?
go here "http://www.dishnetwork.com/support/documents/receivers/default.aspx" to find your remote, then look at the literature to see if APEX is listed or for the code scanning method for your remote. good luck!
Jan 09, 2009 | DISH Network IR Remote Control
APEX CODES
I need the code for my ad-1500 apex dvd so I can program a new remote control
Mar 23, 2008 | Televison & Video
DISH Network IR Remote Control Logo
324 people viewed this question
Top DISH Network Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
