Question about PC Desktops
I can not send or receive my email. chipjoe@sbcglbal.net through att pop/smtp with incredimail
    Guru:
  • 28 Answers
To get our reliable SBCGlobal technical support is much easy for the Technical support seekers, get trusted solutions for your complex issues. We are capable enough to handle any issue of your SBCGlobal email account which is the reason why we are one of the most sought after organizations for getting Technical support. We offer you the quickest solutions which they can't get anywhere.
Visit us for help: Fix Tech Help
Posted on Sep 13, 2016
    Sergeant:
  • 313 Answers
Make sure you have your full email address in the username field
have :
pop.sbcglobal.net
smtp.sbcglobal.net
If you use *with authentication
put these in instead...
pop:pop.sbcglobal.yahoo.com
smtp:smtp.sbcglobal.yahoo.com
If this does not work write back and we will go from there.
Also include the exact error you are getting. Thank you.
Posted on Jul 17, 2008
I just switched to u-verse and have set up an e-mail account using the email adress they gave me. This uses yahoo. That is working ok. However, since I don't like getting my email that way I decided to...
if you can get emails and cannot send one it means that the outgoing SMTP numbers that you put in in your Outlook is incorrect. The best way to resolve this is to ask U-verse for the right SMTP URL for that is the one that is keeping you to send an email.
Oct 03, 2010 | PC Desktops
Camot send or receive out llook exspres
SMTP Server
In the fight against unsolicited commercial email (spam), some Internet service providers require their subscribers to send mail through the ISP's own SMTP servers. If you experience problems sending email, please contact your ISP to determine if it requires different SMTP server settings. You will need to use the ISP's SMTP server in place of Yahoo!'s SMTP server when configuring your POP mail client.
The following is a partial list of ISPs that require you to use their SMTP servers. If your ISP is among them, try replacing the Yahoo! SMTP server with the ISP server in your POP mail client settings, or consult the ISP's help files. If your ISP does not appear in the list below, please contact your ISP directly for more information.
Aug 05, 2010 | HP PC Desktops
I switched to att.net for incredimail and am unable to send e-mai
If you are using windows mail you need to modify you account settings for the new mail server. You need to know your user name and password for your account. You will also need the Incoming Mail(POP3) and Outgoing Mail(SMTP) and if the server requires authentication. You will get this information from AT&T. Once you obtain this info you can modify the current account or add a new one using under the tools tab then accounts.
Sep 16, 2009 | PC Desktops
Message could not be sent. Server rejected sender's email address
the message could not be sent because it rejected as the sender
Jan 15, 2009 | PC Desktops
The issue is: Unable to Send/Receive emails from winThe host 'POP3' could not be found. Please verify that you have entered the server name correctly. Account: 'POP3', Server: 'POP3', Protocol: POP3, Port:...
You are receiving this error because of one of two reasons:
1) Your email account is not set up properly. Click on Microsoft Outlook, click on Tools, then Accounts. You will see a window with columns stating Account-Type-Connection. If an account is set up then click on it then click on Properties. Click server tab and you will see the SMTP server block and the POP3 server block. Both of these fields will read as follows: pop.XXXXX.net and smtp.XXXXX.net. Your Internet Service Providers name will be in the XXXX. If these are not set up properly then you cannot connect to send email. If they are filled out correctly then you need to call your Internet Service Provider and inform them of your situation. Their server is not working properly.
Don't forget to 4 star this solution.
Can not send email from outlook 2003. send: smtp.att.yahoo.com ssl 465
Firstly you need to enable the POP3 settings in yahoo by going to the Options>Mail options>POP & Forwarding.
After that you need  Incoming Mail (POP3, IMAP, or HTTP) : pop.mail.yahoo.com
Outgoing Mail : smtp.mail.yahoo.com
In Advanced Tab Outgoing mail Server (SMTP) : 465 (SSL)
Incoming mail (POP3) : 110 (SSL) OR  995 (SSL)
Jan 02, 2009 | PC Desktops
I'm trying to set up my Eudora for my att yahoo and need the settings
1. Open your email client program.
2. Locate the email account settings for your particular client.
3. Change the POP server to pop.att.yahoo.com.
4. Change the SMTP server to smtp.att.yahoo.com.
5. Check the option labeled Use an encrypted connection (SSL) and change the SMTP port to 465.
6. Check the option labeled Use an encrypted connection (SSL) and change the POP3 port to 995.
7. Confirm the above settings then click OK.
Aug 16, 2008 | PC Desktops
I use Outlook Express for Emailing, i would like to change my present email address please can you help me to do this? Regards Clive.
Outlook Express is just a software which can send and recieve emails from any email account configured on it(Outlook Express). regardless of yahoo, gmail, comcast.net ,aol.com etc.
So if you want to change your email address and want to use it on outlook express, you need to first create an email account by going to the website on which you want to create an email address.
Once you have created the email address we can look for the POP/SMTP server settings of that particular email account on the internet .
Once we have those(POP/SMTP) addresses we can configure Outlook Express to send and recieve emails for your new email account.
Jun 04, 2008 | PC Desktops
Ican receive emails but when trying to send emails I get the error response.
open your email click tools up top then accounts the click on your account and click properties make sure were it says outgoing it says smtp + whatever it says on incoming without the pop
e.g. incoming - pop.tds.net
outgoing - smtp.tds.net
if this doesnt work go to your service provider site it should say on there something about fixing your email settings or connection
Feb 07, 2008 | PC Desktops
PC Desktops Logo
152 people viewed this question
Top PC Desktops Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
