Monitor not working
I have assembled a P-III CPU and tested it at home on my Samsung Monitor, but when I broght it in my Office and tried to use it with an HCL Monitor it showed the initial display but after booting I could not see the display, it showed as it required Horizontol control (as were there in older TVs), What is the reson and is there any remedy?
  • Ravinder Singh Jul 23, 2008
    Thank You very much for the suggetions, I have old monitors at my work place and none of them is an lcd. I am using XP Sp2 on my machine. I could partially start the work on the computer by pressing F8 while booting, and select the option of VGA. but this I have to do every time I want to use the computer. This thing was disclosed by a local repairer friend. I will try the options you gave me.
    Ravi58
  • 558 Answers
You will need to change the display settings for the type of lcd monitor you have, it is a wide screen I am assuming, you can change this by right clicking on the desktop select properties then settings the screen resolution should be on the middle left side and change this until you get a screen that you like There is also an advanced setting then select monitor at the top tab and change to refresh rate to the lowest setting (60 hz) this should get the HCL monitor up then change the setting until they dont work the operating system will revert to the previous settings if you cant see anything after a change. you may also need to use the automated setup on the lcd monitor select auto from the menu (osd). Now if you can not do this on the HCL lcd you may need to use that other Samsung monitor and then set up on that at the lowest resolution so that the lcd can be changed with a working screen. Lastly you may need to uninstall the samsung monitor drivers if you installed those, and leave the generic drivers in for the monitor (plug and play monitor).
I am making some guesses here as you did not tell me if the 1st Samsung monitor was a lcd also , and if the second HCL monitor is a wide screen etc what type of operating system are you running is also important 98 is fussy and 2000 is much more simplified as is XP , vista would be garbage (if you could get it to run on a pIII),
As for reasons for resolution problems, way too many variables to discuss in a short answer forum like this, sufficed to say that the resolution is different because in the past there were lower resolution (less pixels) on monitors, the refresh rates were different by manufacturers and the way the lines were scanned could be different, so setup of the monitor with the video card was also very important interlacing etc was also handled differently until that industry decided on a common standard.
I hope this helps you to get the monitor up and running.
Posted on Jul 17, 2008
My cpu opens but the monitor doesnt starts
Hi Chiver, there could be possible several reasons, such as RAM into CPU or VGA means Graphic Card issue and consequently there is one more possibility with Monitor. Sometimes due to moisture monitor does not show display and in this case you need to keep monitor in the sunshine for hour almost and then it will work perfect.
Good Luck
Feb 03, 2013 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
I have a samsung 2033SW monitor which flickers very frequently displaying that "your optimal resolution is 1600x900.Follow the above settings to set".Though I have set the resolution to 1600x900...
- You can test the monitor by using another CPU, if still the same then the problem is monitor, but if it's working well then the problem is your CPU, to make it sure then you can try another monitor on your CPU. - check if the hardware connection is well attach, you can pull & re- plug the hardware just to make sure. - the monitor is need a DVI connection (white or gray) to run properly, if you use AGP connection ( blue ) on your VGA card that might the problem, so you can also try upgrade your VGA card. - other ways is to install the latest driver for your VGA card.
Jan 14, 2011 | Samsung Syncmaster 2033SW Monitor
My samsung syncmaster 794 monitor light is blinking but monitor not get on
If you tested that to another working CPU but the same problem before, i think that monitor has a problem in horizontal section, check the B+ atlaest 175v if is it normal the power supply is ok, check the H.O.T horizontal output transistor, remove or hang the 3 pins then power on the monitor, if the led did not blinking the H.O.T has fault may be leak,open or shorted.
Sep 28, 2010 | SAMTRON 55V 15" CRT Monitor
Unplugged monitor. left home for a couple of days. Plugged monitor in and got no picture. Turned CPU on and off and the CPU does recognize it, but still no picture. the monitor power button just flashes.
Try it on another PC, if it still does not work and you want to DIY repair, please read below and look at pictures.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 08, 2010 | Samsung 931BF 17" LCD Monitor
My wife's mom bought us a desk top p.c with this samsung 906bw
Well, seems like the CPU is the source of the problems, not the LCD Monitor.
The simple way to check it is by remove the cable from CPU unit, see for any sign such us color pattern moving or any sign.
the other way is, try using other CPU or Laptop, then connect it to the LCD Monitor.If it works, then you need to repair your CPU.
Hope it's working
Feb 22, 2010 | Samsung 906BW LCD Monitor
No display in monitor
Was the monitor tested, that it is working before it was delivered to you? Because it was still under warranty. If your system unit open ( a beep sound hear ) wihen your new monitor was attached only that their is no display but the monitor has a power, means it needs a video card with a driver to be installed. If you have another monitor try it to your computer if the problem still the same.
That's all
Nov 19, 2008 | Samsung 510N 15" Flat Panel LCD Monitor
My monitor displays yellowish color instead of original color
yes please take the power on self test means disconnect signal cable and monitor will give
display without cpu if display appears then monitor ok fault is in cpu if not then fault is in monitor move signal cable and look display changes or not if changes then cable faulty replace it
Nov 11, 2008 | SAMTRON 55V 15" CRT Monitor
UpGrade
download cpuz it will tell your specs
Oct 18, 2008 | E-Machines eMachines Desktop PC
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
M2N-MX SE Will Samtron 55V work?
Does not matter the monitor, has to work , probably u test it on a resolution or frecvency that u're display does not support, try to enter safe mode (for windows) by pressing F8 on boot up , and chose than safe mode, or VGA compatible mode, should work! Change the resolution/freqvency to one that u're display supports
If u have more than one video adapters (one onbord) try to see whitch one is enabled....
Jan 16, 2008 | ASUS M2N-MX Motherboard
Computers & Internet Logo
550 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
