Question about Lands Phones
How do i program my PAnasonic KX-T7720 Handset with an answer message?
    Scholar:
  • 108 Answers
What Voicemail System is connected to your Phone System ??
Posted on Jul 28, 2008
I have a Panasonic answering machine model#KX-TGD390C I want to pick up my phone whilst a message is playing to talk to the person sending the message
Try Googling (Panasonic)(KX-TGD390C)(manual) without parens to learn the answering procedure. Usually you simply pick up the handset.
Mar 29, 2018 | Panasonic Lands Phones
HOW DO I CHANGE ANSWERING MACHINE MESSAGEV ON PANASONIC KX-TGA642C PHONE
The KX-TGA642C is a handset for the KX-TG6421 series phone system. (These are sold as the KX-TG6422 or KX-TG6424, depending on the number of handsets in the initial package.) To record a greeting message, make sure that the phone (all handsets) is in standby. Then press Menu on a handset. Press # 3 0 2 (or use the Up/Down arrow keys to navigate to Ans Device > Greeting > Record Message. Press Select to each menu/sub-menu section.) Highlight Yes and press Select. After you hear the beep, speak your message clearly. Press Stop to end the recording. (The maximum greeting length is 2 minutes.) Press Off to exit the Menu system. If the answering system is on, this message should play.
The manual for the KX-TG6422 has the full directions to change the answering machine message. The direct link to the manual is https://panasonic.ca/PCS/OperatingInstructions/KXTG6411-12-13-14-OI-Eng.pdf . See page 33 for the directions.
I hope this helps.
Jul 03, 2016 | Panasonic Lands Phones
Record message on panasonic phone
The KX-TGA101S is just the handset. The message is handled by whatever base or answering machine you have on your phone line. Please refer to the manual for the base/answering machine.
If you require further assistance, please reply to this post and specify the model of your base or answering machine.
Mar 03, 2014 | Panasonic KX-TGA101S Cordless Handset
I need to delete the message on my panasonic answering machine KX-T7730
The KX-T7730 isn't an answering machine. You need to refer to the documentation for whatever answering/voicemail system you have it connected to. Alternatively, repost your question specifying the make and model of the answering/voicemail system.
Jul 30, 2012 | Panasonic KX-T7730 Corded Phone
Panasonic kx-t7720 telephone is stuck on autodial and the telephone cannot be used to answer calls
You need to disassemble the phone and clean the inside contacts out. This is a common problem and can usually be done with a little 409 and a Q-Tip. Make sure you unplug the phone prior to doing this as it still has power coming to it from the tele. line.
Sep 09, 2011 | Panasonic KX-T7720 Corded Phone
We ask for diminsion (W-D-H) of telephone code No : KX-T7735 KX-T7730 KX-T7720
In inches, approximately 8 w 9 d and 6 high. They're all the same as it's built with the same plastics.
The 5" gives the handset barely enough room to clear the top.
Carl
Oct 12, 2010 | Panasonic KX-T7730 Corded Phone
I forgot my vm password and cannot retrieve my messages on my Panasonic KX-T7720 phones. How do I reset the password??? I have a TWA848 phone system and TVA50 voice processor. thanks in advance.
Just hope the owner didn't forget the password to the sytsem manager's box (999). From that box, you can reset any user password. If you lose the passwords to MB 998 and/or 999, your installer/tech will have to give them to you again.
Feb 05, 2010 | Panasonic KX-T7720 Corded Phone
Program manual
Your phone will work on a few different Panasonic phone systems. If you are looking for manuals on KX-T7720 and KX-T7720 all you will find is a user guide for the phone. You need to determine the model number of your phone system before starting to look for a programming manual.
Jul 17, 2007 | Panasonic KX-T7730 Corded Phone
Answering system
It first sounds as if the handset isn't charged properly. Check the battery status first. The manufacture advises to charge the system for approx. 7 hours before any use occurs. Second, make sure that the registration took, when programming the phone originally. I would de-register the handset by: 1 {MENU} i {0}{0}{2} 2 {3}{3}{5} i {OK} 3 Select the handset you want to cancel by pressing the desired handset number ({1} ? {4}). Then re-register by: 1 Handset: {MENU} i {0}{0}{1} 2 Base unit: KX-TG6021/KX-TG6022/ KX-TG6023 Press and hold {LOCATOR} until the IN USE indicator flashes. KX-TG6051/KX-TG6052/ KX-TG6053/KX-TG6054 Press and hold {LOCATOR/ INTERCOM} until the IN USE indicator flashes. LAfter the IN USE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 3 Handset: Press {OK}, then wait until a beep sounds. 4 {OFF} Third, make sure that the display on the handset does not show "SP-Phone" in the display, if it does press the phone icon button. Fourth, Do you currently have voicemail from your phone service provider? If so, the answering machine will not answer. Make sure that the answering machine portion is turned on. Do this by: Press {ANSWER ON} to turn on/off the answering system. When the answering system is turned on, the ANSWER ON indicator lights. When the answering system is turned off, the ANSWER ON indicator turns off. If there are any further questions or comments, please post here. Please rate this solution through fix-it. Thank you
Jun 22, 2007 | Panasonic KX-TG6021 Cordless Phone
Lands Phones Logo
78 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
