Question about Paradigm PS 1200 Speaker
Auto on stoped working
The "auto on" function has stopped working (i.e. the sub no longer works). Initially I could bring it back to life by pulling out / inserting the power chord. It became gradually worse and finally this workaround no longer worked.
Expencive repair?
  • 2 more comments
  • bajen14 Sep 09, 2008
    I have the same problem, my auto on stopped working.
  • Anonymous Dec 02, 2008
    bought used as working, but it will not power on
  • Anonymous Dec 14, 2008
    Hi, i'm Ole from Norway and i have the exact same problem.
    I don't have any solution, but i see that your question is from 6 months back. Have you been able to fix it? If so, please let me know how.
  • cdnsolman Dec 18, 2008
    I also have that problem, (PDR-10) I've checked the power supply components, and they are all fine, there is something in the electronics that won't get the signal through to the amp.
My definitive technology pro cinema 600 sub stopped working
theres a setting is on the subwoofer itself, not the AVR. It usually has 3 positions: On, Auto, Off. Auto allows the sub to "sleep" when it's not being used, and to power back up fully when it senses a signal. Maybe change to On position which would bypass that auto mode
May 07, 2017 | Definitive Audio Players & Recorders
Auto start quit working, started losing distance, finely quit working, tried new battery , all other function work!
Remove the auto start. One wire at a time. Fix cut wires. Do it right, your car will come back to life.
Dec 15, 2016 | Cars & Trucks
My Power front windows with "auto" function on jeep grand cherokee work intermittently
Check for binding in the tracks. A little time spent cleaning can yield a marked improvement.
May 31, 2016 | 2005 Jeep Grand Cherokee
Auto Down window feature stopped working. Any ideas?
Try calibrating first,window up & hold switch for 3-4 seconds window down hold 3-4 seconds then back up & hold 3-4 seconds,check for the auto down to work if not then most likely the master switch is needed.
Oct 10, 2015 | Chrysler PT Cruiser Cars & Trucks
I have a 2001 jeep cherokee sport. at first the passenger windows only work from drivers side. was having trouble with the drivers side which worked so often. drivers window would go up and would not...
One Problem.
All Of The Window Controls Are Controlled By The Master Switch, Which Is The Drivers Window/Door Lock Control Assembly In The Door. Sometimes A Removal Of The Control Assembly And A Through Cleaning Can Bring It Back To Life. More Specifically The Window Lock Button. This Is Why The Other Windows Have Stopped Working At The Door But The Drivers Control Still Operated All The Doors Just Fine. Next To Go Bad Is The Auto Down Function. basically The Inner workings Of The Switches Are Gunked Up. Take the Driver Side Door Panel Off, Remove The Door Lock Assembly From The Panel. It Can Come Apart, But It's A Three Hands Kind Of Thing. The Buttons Pry Off, But Be Careful They Will Fly Across The Room. Once You Open The assembly wipe Everything Down With Some Cleaner, I Used A rag And carb Cleaner. I Did This And It Worked For A Couple Of Months. It Was Much Easier To Order A New One From Rock Auto.Com, It's Plug In Easy. 1.5 Hours If You've Never Taken The Door Panel Off Just Because You Have To Be Patient. My Replacement Been Working Great For 2+ Years. Cost ~ $60.
Sorry For The Weird Caps, Phone Reply.
Jun 02, 2014 | 1998 Jeep Cherokee
Sigma 50-500mm auto focus problem
Hi is the manual focus working from inf to close focus and not stoping then it needs a new hsm motor
Jun 07, 2009 | Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens
Fuel gauge, temp gauge, and auto door locks stopped working while in transit. checked obvious fuses, found no problems. did not check all fuses. Ideas
I had a similar problem with a 2001 Saturn. We checked every fuse and they were all fine. We finally did a 'reset' on the car's computer by disconnecting the battery and reconnecting it a few minutes later. Everything was back to normal after that.
May 27, 2009 | 2002 Chevrolet Malibu
Drivers Power window stopped working
test the switch and motor w/ regulator on with a voltmeter. if all comes back fine check the motor w/o the regulator.
Apr 28, 2009 | Isuzu Rodeo Sport Cars & Trucks
ASW1000 sub bass
Auto sensing circuits function when a certain level of audio output is reached but the transition from off to on can be abrupt, annoyingly so. Another problem is that you may have to set the system volume level higher than you would prefer to get the sub to turn on. I am currently using a sub that does not have this "feature" and performance is more predictable.
Jun 01, 2017 | B&W ASW1000 Speaker
Paradigm PS 1200 Speaker Logo
96 people viewed this question
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Don Hart
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
