Question about Canon PowerShot G2 Digital Camera
Problem5959 with G2 Digital cam
Cam down to water. Can I repair pictures from camera?
  • 3 Answers
SOURCE: can i connect this camera to my computer and use it as a web cam
No, digital cameras usually cannot be used as webcams unfortunately because they do not have the correct softwear to hook up to a computer.
Sorry!
Posted on Feb 22, 2008
SOURCE: stealth cam digital game camera not taking night pictures
i opened up the unit and found the wire from the cover had became loose from its soldered point, where does it go so i can resolder it.
Posted on Sep 04, 2008
  • 207 Answers
SOURCE: i have a digital camera(samsung860) and i have
Dear Sir,
I'm not sure what led you to believe that your camera can be used as a webcam, but based on the user manual I was able to download for the product you listed, it does not mention that ability/capability. You can look at your user manual here:
http://downloadcenter.samsung.com/content/UM/200902/20090202162312203/S860_760_English.pdf
I'm sorry if it's not what you wanted to hear. Best of Luck!
Posted on Apr 23, 2009
greenspan
  • 1734 Answers
SOURCE: Free software/drivers Vivitar Digital Camera
This is not free, but they can get you every Vivitar driver
Posted on Jul 24, 2009
  • 83 Answers
SOURCE: Use of digital camera Lumix DMC-LS70 as a web cam.
It will not work through USB like a standard webcam. Ls-70 only lets you access camera memory card/onboard memory when connected via USB.
However you could connect the camera video-out socket to a PC with graphics card with video capture function. Some cards with video capture work with skype (check this URL:
http://forum.skype.com/index.php?showtopic=41101 )
There are also various software solutions which can fool your webchat client into thinking that video capture stream is actually an output of a usb webcam. (Try google for "video capture into skype".
At the moment this seems to be the only easy way to use LS-70 as webcam.
Good luck,
Raf
Posted on Nov 05, 2009
Dear sir , photoprints from my camera shows parellal lines when the picture is zoomed the lines becomes bold from...
This is can be due to sensor damage or memory card damage.
  • Card damage (maybe repairable).
This is common with Flash memory that has been used extensively for a long time and this problem is likely not caused by any fault in the camera.
To check whether the damage is on the card or on the camera, copy a good picture from your computer and check it a few days later with a COMPUTER. If the lines appear on them too, you can say that the card is damaged.
If you want to try to use the card again, You can try formatting it (method differs from cam to cam, check instructions manual for specific instructions)
If this doesn't work, You will have to buy a new card. Make sure you buy a good brand like Lexar or SanDisk.
  • Sensor damage (unlikely to be repairable):
If you pointed the cam directly at something very bright like the sun (for taking pictures of an eclipse for instance), some parts of the sensor will get burnt. In this case you will get oddly colored dots all over the pics in the same places.
Parallel lines are consistent with other kinds of sensor damage like because of water.
I'm afraid that you might not be able to find someone to repair this cam; it's not a professional DSLR camera. which means repairs to it can cost more than buying a new camera will!
May 02, 2011 | Canon PowerShot A470 Digital Camera
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
I have a problem with my camera. When i want to make picture my camera don"t have image, but have sound. LCD display is black
after taking the picture connect it to the computer and see there if any image or video is available.if yes then your cam's lcd display has problems.either it needs to be repaired or it should be replaced.probably you should have dropped the cam down hard.please take it the nearest service center to get it done since it needs a pro to change it.please do not try to repair it yourself unless you know well, how to do it.i am telling this since the cam needs re-calibration after being opened.
Jan 01, 2010 | Canon PowerShot A60 Digital Camera
THE lCD broken but the cam normal ,still on, can take a picture
Certainly your camera is damage by mishandling. Sometimes repairs cost more than buying a new one. so better ask first the cost of repair before having it done. don't hate it's your fault anyway. Charge it to experience.
Sep 22, 2009 | Canon IXUS 860 IS Digital Camera
Wont take pictures
If every thing is working on the cam but the camera, and your cam has a built in memory, take the memory card out. Try using cam with just built in memory. Sometimes the cam wont format right with the memory card. Don't know why, but it just happens. If this works, you'll have to get another memory card. If the cam doesn't read the memory card, it will still work, but it won't take pictures.
Aug 30, 2009 | Bushnell Trail Scout 11-9500c Digital...
Software download
want to use camera for pc cam but lost cd need assitance
I have a optimus digital video cam cat. no. 16-3845 for which I lost the cd to download my pictures from the camera. can you help?
Aug 29, 2008 | Cameras
Casio exilim ex-z70
Sounds like ccd issue. Some people have reported similar problems when cam is exposed to water (moisture) or if it's been dropped. Contact you local Casio service and ask them details. They probably just say that send the cam to repair but that is expensive, at least in here Europe.
Jul 22, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Stealth cam digital game camera not taking night pictures
Jul 04, 2008 | Advanced Electronic Support Stealth Cam...
[Casio Exilim EX-S500] Lens will not retract
Nearly one year!
Then be quick and send it back under warranty - waste no time.
May 22, 2007 | Casio Exilim EX-S500 Digital Camera
Cant charge camera on dock or print photos
the dock won't charge batteries that are ni-mh kaa2hr or Li-ion battery pack - so check that
about the printer's ability to recognize the cam, try this.. remove batt, put cam on top of dock (when cameras are on a dock, they can use the dock's power so you can print pictures without batteries) check if somethign will come up on the cam screen
if not .. either would need to be sent in for repair. a digital rep will advise you to send both so the repair center can check
Mar 09, 2007 | Kodak EasyShare CX7525 Digital Camera
Canon PowerShot G2 Digital Camera Logo
35 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
