Can't adjust power settings to allow monitor to stay on longer
  • 149 Answers
Make sure you're in admin account.
can't adjust power settings to - a47a394.jpg from start menu
5bf8a87.jpgfrom control panel
from tabs
d61d7d7.jpgfrom that page
7d536c6.jpg Then click OK, and you're done!!!!!!!!!!!!
Please Rate!
Posted on Jul 17, 2008
  • 6 more comments
  • john doe
    john doe Jul 18, 2008
    why you rate inapropriate, thats how you do it!!!!!!!!!!!!!!!
  • john doe
    john doe Jul 21, 2008
  • john doe
  • john doe
  • john doe
    john doe Jul 25, 2008
  • john doe
  • john doe
  • john doe
    john doe Aug 10, 2009
    Jul 25, 2008 - why you rate inapropriate, thats how you do it!!!!!!!!!!!!!!!
Make screen stay on longer for my surface tablet
Should be adjustable under power settings.
May 23, 2014 | Dell Computers & Internet
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
I JUST PURCHASED A NEW 19INH AOC MONITOR TO USE WITH MY E-MACHINE. IT WORKS FINE EXCEPT IT SHUTS DOWN WHEN I LEAVE THE COMPUTER AND STAYS THAT WAY UNTIL I MANUALLY START IT AGAIN.
Hello Eldon, don't worry this is a safety devise that is built in to your unit and many others. It gives your screen longer life. GOOD LUCK.
Oct 22, 2011 | AOC 931SWL 19 inch Monitor
On power up the display stays dark for about 2 minutes, then starts to make very short flashes of the regular display, which gradually stay on longer and longer. After about a minute of that, the display...
Yes, very likely to bad dying caps, and if you keep using it, it will cause more damages.
As you can see the failed SAMSUNG monitors and TV albums here:
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Feb 06, 2011 | Samsung SyncMaster 204BW LCD Monitor
How to prevent my computer to shut down automatically?
Control panel, power settings, set the times you desire in there and you can have it stay on longer or shorter, shut the monitor and drive or just shut the whole thin is as many minuter or hours a s you like, The longer it stays on, of course the shorter the battery life
May 21, 2010 | Acer Computers & Internet
When the screen is not used for a little while it goes in the sleep mode and I have to turn it off and back on. Is this normal
Normally a monitor will come out of sleep mode merely by moving the mouse or hitting a key on the keyboard. It all has to do with your power settings. If in Windows, click on START/ControlPanel/Power Your Power settings determine how long your monitor stays on as well as hard drive disks when computer is idle. Just select a longer period of time or "Never" for monitor shut off settings.
Nov 07, 2009 | Acer 22" X223w LCD Monitor
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
Monitor "sleeps"
There are two places where the sleep time can be affected, both of which are accessed through the Control Panel that is normally an item on the Start menu.
Check the Display folder first and look for Screen Saver. This can be turned off completely or set to longer delays. The second, is the Power Options provided more for laptop users to conserve battery life but also can control the shutdown of your monitor.  Power Options aren't too important to desktop machines but the options are still listed.
Dec 25, 2008 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
24 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
