Question about Danby Refrigerators
Hi, I have a Danby Ice maker DIM1524 and when i tried to start it for the first time this year, it gives me an error message (bucket full) blinking. I tried cleaning it and the pump and cleaning process seems to work fine.
I braught the unit at an authorised service depot
Posted on Jul 18, 2008
What does Er 1F mean of the control panel?
I believe the 1F error indicates a problem with the ice maker. This could be an issue with the ice maker fan icing up, the fan motor failing or the PCB board that controls the fan. First try unplugging the power to the refrigerator for 8 hours. This may reset the error code. Next check if the fan is spinning freely. If the fan has iced up, then the motor could fail from the attempt to spin the fan.
If you add a comment with the full model number, I may be able to give you the parts information. (Look inside the refrigerator for the model number; there is usually a plaque with that data on the side of the fridge.) If your refrigerator is under warranty, contact Kenmore.
I hope this helps.
(If you turn off the ice maker after resetting the code, you probably won't see the error again.)
May 14, 2015 | Kenmore 72093 Elite Stainless Steel 32.5...
Can this ice maker be set to make more ice? And faster?
Icemakers cycle cubes from the air temperature inside the freezer so you can't do much to increase speed except adjust the freezer control colder. As to the bucket not filling, most icemakers have a feeler arm or plastic paddle that is suppose to sense the ice level in the bucket. Make sure the feeler arm or paddle at the bottom is free and no sticking or hitting anything. It needs to move freely ask the icemaker dumps the cubes. If your refrigerator is less that a year old it should be under warranty and a free repair to you.
Apr 30, 2015 | Samsung RF4267HARS Stainless Steel French...
Ice maker on/off light?
ice bucket full and/or door open so ice maker does not dump ice when you have door open.
Apr 04, 2014 | Refrigerators
Our Kemore fridge stoped making ice. water is coming.. It has infra red light control for ice maker to stop when bucket full of ice.
Open up the door ,hold in the bracket that is on the side(usually lrft side) and if the sensor light keeps blinking,it has to be replaced.HOpe this helps if so give us a 4 thumbs up. THANKS
Mar 03, 2011 | Kenmore 53642 / 53644 Side by Side...
Need Replacement Parts!!!!!
You can go to the sears web site and get it it should be under warrenty or you cna go to http://www.appliancepartspros.com and call and ask them they can give you where to locte it nearest to you and the list price for it. Hope this helps.
Dec 28, 2009 | Kitchen Appliances - Others
I HAVE DABY ICE MAKER DIM1524 AND THE FAN TO COOL
I REPLACED THE FAN AND THE ICE MAKER IS WORKING JUST FINE.
Jun 10, 2009 | Danby D9604 Refrigerator With Ice Box
Ice maker not making ice. red light on control panel blinking twice.
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Jan 07, 2009 | Hotpoint HSS25GFP Side by Side...
Danby icemaker not pumping water
I have the same problem, the ice shovel was catching and not moving forward to shovel the ice, this stopped the ice maker. i have cleaned off the surplus plastic from the molding process (on the underside of the shovel) and this so far has cued the problem.
Jul 16, 2008 | Ice Cream Makers
Refrigerators Logo
343 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
