Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer
Every time I try to turn on my Maytag Neptune wash machine I see the letter OD show up on the display and it will not turn on. I have to get behind the machine and unplug it and then plug it back in before it will turn on. How can I get this resolved. What does OD stand for?
Thanks,
Nancy
    Scholar:
  • 50 Answers
It stands for 'open door'. The control board didn't see that you've opened the door since the last cycle and won't start another cycle until it see's that. Probably a bad switch in the door latch assembly. If you can verify a bad switch, it's best to replace the whole latch assembly. It also may be a shorted wire, trace the wiring back from the latch to the board and check for any signs of damage. It's possible, but very unlikely, that the control board is bad. If everything else checks out it's the board.
Posted on Jul 18, 2008
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
I have a letter showing and it say O D WHAT IS
You have lost signaling out of the Left Hand Lid Lock.
The Service Manual for reference. Sears Parts Direct for reference.
See this link for OD troubleshooting. If you have questions post back and I will help you….Rich
May 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune washing machine displays OD and does nothing
See if this post will help you clear the OD error code on your machine.
Sep 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
"od" = Door Open. Most likely a relay or wax motor in the door latch assy.
Jan 09, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Washer, Neptune TL
This means the computer is not seeing that you opened the lid between cycles 3 times. So likely the lid locks are faulty. PLEASE rate my help as solved all other ratings dock us
Oct 02, 2007 | Maytag MAT13MN Top Load Washer
Error Code "od" while trying to start machine
Could od mean overload? Reduce or actually weigh load and re-try
Apr 15, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
