How can i repair a optoma 706 lcd displaying white and black vertical lines?
    Sniper:
  • 59 Answers
FAULT: If lines are flickering with black and white and there is no data in line its mean the DLP unit is faulty.
SOLUTION: the only solution is this that you replace the DLP unit the DLP unit is electroniccomponent and not a repairable (as show in picture) how can i repair a - good_help_19.jpg
Posted on Feb 10, 2011
SOURCE:
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
Two vertical 1'' white lines on right side of Lcd panel
If the lines are parmanent, Then suspected part is LCD Panel.
Dec 27, 2009 | Samsung 226BW Monitor
Flashing black and white vertical lines
Vertical lines in the display indicate a failing screen. New screens are expensive and not worth the labor and parts charges to repair it. It's new monitor time.
Jul 28, 2017 | Samsung LTN1535 15 in. HD-Ready LCD...
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Vertical lines showing. it is an Optoma HD70
If the lines present in the menu when displayed this indicates device mounting troubles. Possibly loose in socket. If you change aspect of displayed image do the lines move, if they do, its an electronics problem, if they are constant, and nothing is displayed in the lines. Tighten device in socket, or seek professional service.
Jul 07, 2009 | Televison & Video
I have laptop dell inspiron 9300 it 17 sreen , it has a white verticle white line about on the middle about inche 1 1/8 wide hohow to fix? thank you...very much
Unfortunately, there is no way to fix it.
This line called "Tab Separation" of LCD.
You'll need whole new LCD display.
Very very common problem.
Apr 29, 2009 | HP Pavilion zd8000 Notebook
VERTICAL WHITE LINES
I just read a post that said tap on the top and the line will go away. I tried it on mine and it worked! I had to tap it fairly hard. I just kept tapping harder and harder on the plastic in front of the buttons and voila! The vertical white line disappeared!
Oct 07, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
White screen lcd display
Your LCD is starting to go out. Call their repairs dept to have it fixed. 1-800-706-2534 option 2. Tell them that you have already talked to tech support otherwise they will make you call a bunch of different phone numbers.
Nov 25, 2007 | Casio Exilim EX-Z750 Digital Camera
Open Questions:
518 people viewed this question
k24674
Marvin
Marvin
