Question about HP Office Equipment & Supplies
My new hp photosmart c6250 will not print to my computer. the menue only gives the option to reprint or scan to memory card
I reinstalled the program and will control the printer from my computer. The scan menu still does not say, 'scan to computer', as the basic guide book says that it should.
Posted on Jul 19, 2008
Can you just give me a link or quick advice on scanning with HP photosmart c5180? I would like to to scan and save to disk/save to laptop.
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N43
FROM THE MANUAL ON PAGE 14 http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Scan an image You can start a scan from your computer or from the HP All-in-One. This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning. ? On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running. Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software. ? On a Mac, the software is always running. Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One. To save a scan to a memory card 1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One. 2. Load your original print side down in the right front corner of the glass. 3. Press the Scan Menu button. 4. Press to highlight Scan to Memory Card, and then press OK. The HP All-in-One scans the image and saves the file to the memory card in the JPEG format. To scan a photo and reprint it 1. Press Reprints. 2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following: To reprint your original photo using the default print settings ? Press Print Photos. To change print settings before reprinting your original photo a. Press OK. Basics Guide 13 HP All-in-One overview b. Press or to highlight a paper size, and then press OK. The paper size choices available vary depending on your country/region. Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages. c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK. The HP All-in-One scans your original and shows a preview of the photo on the display. d. Press OK to display the selection menu. Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies. If you want to edit the photo before printing, press to highlight Edit Photo, and then press OK. e. Press to highlight Done, and then press OK. The Print Summary screen appears. f. Press or to highlight one of the following options, and then press OK. Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and time stamp on your photo. By default, the Paper Type is set to Automatic and the Date Stamp setting is set to Off. If you want, you can change the defaults of these settings with the Set New Defaults option. Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and wasting paper and ink on potential mistakes. Print Now Prints your photo with the size and layout you selected. To scan to a computer 1. Load your original print side down in the right front corner of the glass. 2. Press Scan Menu. 3. Press to highlight Scan to Computer, and then press OK. 4. If the HP All-in-One is connected to one or more computers on a network, do the following: a. Press OK to select Select Computer. A list of the computers connected to the HP All-in-One appears on the display. Note The Select Computer menu might list computers with a USB connection in addition to those connected through the network. Chapter 1 14 HP Photosmart C5100 All-in-One series HP All-in-One overview b. Press OK to select the default computer, or press to select a different computer, and then press OK. The Scan To menu appears on the display, listing the applications on the selected computer. If the HP All-in-One is connected directly to a computer with a USB cable, proceed to step 5. 5. Press OK to select the default application to receive the scan, or press to select a different application, and then press OK. A preview image of the scan appears on your computer, where you can edit it. 6. Make any edits to the preview image, and then click Accept when you are finished.
Jun 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
Scan to Computer is not one of the listed options. The only choices on the scan menu are Scan & Reprint or Scan to Memory Card. I need to scan and email documents but can't seem to get the ability to...
Did you install the HP software that came with the scanner? I believe it is called the "HP Solution Center". If so, you can open this program to scan. Once you scan the item, you will have the option of where to save the file.
Feb 28, 2011 | HP Photosmart C6280 Printer
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
Scan an image
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
● On a Mac, the software is always running.
1. Press Reprints.
➔ Press Print Photos.
a. Press OK.
Basics Guide 13
Defaults option.
2. Press Scan Menu.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Scanning
Right click on the card in My Computer.
Click Properties, Uncheck READ ONLY
Jun 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Trying to scan pic from phto to pc and only gives me options of scan and reprint or scan to memory card all i want to do is put a phto on my pc?
You could scan to the memory card, and then transfer the file from the memory card to your PC with a card reader, or your digital camera.
Mar 30, 2009 | HP Photosmart C4180 All-In-One InkJet...
Wanting to scan from scanner to computer
this happened to me too. i don't know how to fix it on the printer, but i scanned it through the computer. i went into the hp solution center, went to the scanning section, and told the printer to scan it from the computer. it worked fine. that way you don't have to save it to a memory card or anything. they went to the same folder all my other scans go to.
Jan 13, 2009 | HP Photosmart C4150 All-In-One InkJet...
MY HP PHOTOSMART DOES NOT GIVE OPTION TO SCAN TO PC
First make sure that the software is sucessfully installed in you computer and then try the steps metioned bellow.
Go To My computer>C:\Drive\windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:\Drive\windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:\Drive\Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Dec 21, 2008 | HP Photosmart C5280 Printer
HP Photosmart C5280 Printer -scanning
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Jul 20, 2008 | HP Photosmart C5280 Printer
HP C6180 won't scan to word or document viewer etc etc
the save as function is in the print/scan manager, not the software..you'll need to point it to where you want it to save, and also what format
May 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
196 people viewed this question
Ben Johnson
