Question about Tatung V23DLWX Television
Input/output voltage I am looking to replace a powersupply unit on my tatung 23' LCD tv; model number v23dlwx. Can some one tell me what the input/output voltage required is or how to find it? Or, give me any ideas as to how I can fix my tv without the actual replacement part (cause I can't find it.)
  • Anonymous Mar 17, 2014
    horizantal driver transsister input voltage low.without transister comming normal voltage.new transister change ed but same problems.so please help me ic f1000
  • 4 Answers
Here is a manual that may help.
http://pettersservice.com/polaroid/docs/FLM-3001ServiceManual.pdf
Posted on Jul 18, 2008
Power light come on but no pic or sound, what sholuld i do? is there a cheap way to fix this problem? and for how much?
There is no cheap way to fix, it iwll require in-depth troubleshooting, repair shop will easily charge you $100 and up plus parts.
The power supply may have gone out, please read my guide to get some idea what to look for.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 01, 2011 | Tatung V23DLWX Television
Over time, my 2007 Samsung LCD TV, model LNT4665F has developed random vertical pixel noise lines scattered throughout the screen. What could be causing this?
This TV is known for powersupply failures and this can be effecting the incoming voltages into the mainboard (AKA tuner board). This would cause the noise. Please have someone look into the powersupply and check that the proper voltages are coming from it. If they check out ok, you need to replace your mainboard.
Please rate if this helped :)
Mar 30, 2011 | Samsung LN-T4665F 46 in. LCD Television
Ok my probem is my tv no video and yes audio
Ur LCD inverter board is dead.Replaced this board will get ur picture back.It a long board.Tries Shopjimmy.com Ebay.com to buy a refurbish LCD inverter backlight board.
Feb 17, 2010 | Tatung V23DLWX Television
Pop fuse when pluged in
yes it may very well be the horizontal output transistor or the voltage regulator ic or a shorted rectifier diode on the power supply or the b+ capacitor on the powersupply good luck
Jan 20, 2009 | Televison & Video
Rca remote
Order the original remote. Do a Google search on the net for the tech support for your set. They will tell you how to order original parts for your set.
The universal remotes do not do all the functions, and they are not really gauranteed to work well with every model available on the market!
Jerry G.
Jul 08, 2008 | Tatung V23DLWX Television
23 inch Ilo LCD Tv Model # v23dlwx
You have a bad inverter board.
Apr 25, 2008 | Televison & Video
TATUNG 30" LCD HDTV MONITOR WILL NOT TURN ON
I found a replacement Scheda power module at you guessed it, not at Toys R Us but rather at www.tvmodulesrus.com for $79. The same module is used in several LCDs, including our PowerSpec 30" LCD sold at Micro Center. It is listed under several numbers at TV Modules R US:
P/N: 6693006610
Model: HOAU242001(A)
Scheda Inverter PWB-0656-03
Nov 28, 2007 | Tatung V30DMTT 29.6 in. LCD Television
Is the iLO v23dlwx the same as the Tatung V23dlwx
www.polaroidsupport.com/polaroid/docs/FLM-3001ServiceManual.pdf
Nov 16, 2007 | Tatung V23DLWX Television
Tatung LCD television
The power outage simply precipitates a pre-existing flaw in the power supply unit of this TV. You will need to either order a new power supply and put it in yourself, or send it to Tatung to fix. I had the same problem. Contact this person:
Vila Khamkathok
Customer services supervisor
Tel: 800-827-2850 x161
Aug 06, 2007 | Tatung V30DMTT 29.6 in. LCD Television
Tatung V23DLWX Television Logo
151 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Josh Whitehead
Josh Whitehead
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
