Question about Vizio L32 32 in. LCD HDTV
L32 won't power up
Same as many others it appears. Screen totally black led is yellow, no sound or anything else.
    Sergeant:
    Champion:
  • 417 Answers
Faulty send it back if under warranty cost you more to get it repaired not worth it
Posted on Jul 17, 2008
LG 50PZ750-UG Intermittent picture and sound.
It is likely the best thing to do here money wise is replace the TV.
Aug 25, 2016 | LG Televison & Video
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 15, 2012 | Computers & Internet
Hi, I bought a Vizio L32 HDTV10A that didn't power-up. There were charred components on the power board (an 8-pin IC with heatsink and 2 resistors). I replaced the power board, and the power LED then...
change the mother board. the ic took a hit after the power board went off. it will test good without stress, but under power stress it break down. measure the output with osciloscope to check the waves you should get a saw tooth wave if the the ic is good under stress.
Mar 07, 2017 | Televison & Video
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
Samsung laptop black screen
Sounds like a loose connection between your mainboard, inverter or LCD. Try to connect an external monitor and see if the display appears to the external monitor. If a display appears on the external monitor, you need a qualified technician to check your laptop. I fixed 3 laptops with that same symptoms, 1 has loose connector, 1 has ground problem and the other is an inverter.
Apr 09, 2009 | Intel Motherboard
Vizio 32 does not turn on
The tv not not power 0n dead set,1 ic blown out stby sw,how I can fix the board.Thank you.
Jun 21, 2008 | Vizio L32 32 in. LCD HDTV
L32 standby power only
I just had the same problem fixed. It is an internal problem with the "main board". You have to actually replace it. I am looking into fixing my other one identical to my other one and the identical problem too. Vizio fixed on "out of warranty", but for some reason will not fix the other, I guess I should be thankful, at least I know what the problem is.
Dec 29, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
