Question about AEG Washing Machines
Wnat to convert a uk washing machine and dryer to use in usa . there is a 220 outlet of course but where do i get a 2 outlet plug for the machines that will then plug into the usa dryer 220 outlet.
  • 41 Answers
There is a possibility that your machines may not work properly in the usa as they generate electricity at a different frequency than uk 60 hertz usa 50 hertz uk also most of the equipment in the usa is 120 volts not 230
Posted on Jul 17, 2008
Our machine has suddenly stopped do they have a fuse thats replaceable
Only in the UK and Australia. The fuse in in the plug or in the fused spur that is hard wired. In the USA and Canada, it would be a normal wall outlet covered by a breaker.
Aug 21, 2016 | Washing Machines
Can I use the charger with the 220 in UK ?
Unless it is rated for 220-50/110-60, you will need the converter. Besides the 110V US plugs won't plug into the 200V UK outlets.
Apr 14, 2015 | Dewalt 12v Max - 20v Max Li-ion Battery...
Bought a singer from the state but cannot be used in australia what should i do?
If it is an electronic or computerized machine, you are out of luck. USA has 110 volt 60Hz current, Australia has 220 volt 50Hz. A transformer can change 220 to 110 volts, but it cannot change 60Hz to 50Hz.
Sep 21, 2011 | Singer 4423 Sewing Machine
I am trying to hook up my stackable washer and dryer. I havee a 220 plug 30a what do I need to do so I don't have to go back to home depot and get whole new plug in and plug?
If the unit has a 30 amp/220volt plug, then you will need a dedicated 30 amp outlet from a 220 volt line from the panel. You can not switch the plug to work with a regular (15-20 amp) outlet. Have an electrician install a 10 gauge 220 line from the panel to the unit. good luck!
Aug 30, 2011 | Whirlpool LTE6234D Top Load Stacked...
Maytag Dryer Model ALE868QAW given to me has no manual -only the timer rings nothing else-plugged into 220 outlet
You high limit is mounted on the heating element. Very simple machine to service. Pop the bottom panel off therethemobilian_1156.jpgThe red klixon is the 250f limit and the smaller klixon is the thermal fuse. It dies and she won't run at all. Of course it could be the door switch also. themobilian_1157.jpg
I have a service manual and more HERE
Jan 30, 2011 | Maytag Dryers
Need to know how to convert 3 prong 220 power cord to 4 prong rerouting neutral/ground to separate conections
You will find the procedure at this web site
http://www.ehow.com/how_5946909_change-electric-dryer-4_wire-plug.html
Mar 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool stacker washing machine works dryer doesn't
The problem is probably with the outlet. The washing machine motor is 120 v and the dryer is 220 v. If one pole of the two pole breaker is bad you could end up with the symptoms you have. I have seen this happen before. go to the circuit breaker and push it all the way to off (it may feel like you are crunching something inside...don't worry) then turn it back on and try the dryer. If this doesn't work, unplug the unit and test the outlet with a voltage tester. you should read 220-240 volts across the two slots and 120 volts from each slot to ground. If not, it is time to call an electrician.
Jun 22, 2009 | Dryers
Kenmore Dryer 697267
Most dryers are 220 so they can produce the amount of heat required to properly dry clothes. I would Not recommend trying to convert the dryer to 110 voltage. This may cause you alot of unwanted problems. I would find a Qualified electrician to install a 220 outlet at the location of the dryer .
Apr 26, 2008 | Dryers
Washing machine temperatures
usually high setting is off at 155 F medium 140 low 125 PLEASE rate my solution as solved if you feel I answered your question accurately.. Thanx
Oct 02, 2007 | Dryers
Washing Machines Logo
103 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
