Question about GE JGRP17 Gas Single Oven
Gas Oven Problems
I have a Gas stove with electric ignitor. Everthing works great except the oven part. Before it went out, when I would turn it on to cook, it would click, then all of the sudden after months of doing this it, it quit heating. What would fix this? Where could I get a part to fix this problem if I can?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
I've got an amana gas oven range and just had the ignitor replaced. Everything seemed to work great afterwards for about 2 hours but then the breaker tripped. I let the oven cool down before I reset it...
What you want to check or have checked is if the wiring on the new igniter was accidently not properly insulated and some or the wiring is bare and touching metel shorting the breaker each time the oven is turned on.
Aug 16, 2011 | Magic Chef 9512 Electric Single Oven
I have a roper free standing stove. Everything seems to work except the oven. When I turn the thermostat to broiler it works but doesn't when I turn to oven
next time send the model number and say if it's gas or electric?if it's gas you have a bad bake ignitor,if it's electric you have a bad bake element
Apr 22, 2011 | Ovens
My gas stove, the top works but the oven doesn't. I think the pilot light went out,how do I relight it?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Feb 12, 2011 | Maytag Ovens
My oven does not heat up. Everything else on the stove works (top burners, clock, timer, ect.) When you turn the oven dial, it even clicks as if it were to start the oven.
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 10, 2011 | GE JGRP17 Gas Single Oven
I have a magic chef gas stove witch has electric pilots.when i turn on oven it seems the electric pilot lights up but the burner doesn't come on.
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Jan 06, 2011 | Magic Chef Ovens
My frigidaire self cleaning stove(FGF368GM ) isnt lighting.... how do i light my stove?
heatman101
Sep 16, 2010 | Frigidaire FGB24S5A Gas Single Oven
Kenmore oven and broiler do not work
Hi and welcome.
Just because you see a glowing ignitor that does not mean it is "good". You need to check the circuit amperage to be sire. Weak ignitor are ultra-common for the appliance technician to see. The minimum amperage required to open the gas valve is around 2.9 amps. if you have access to an amprobe, read the amperage draw thru one of the ignitor's lead and you will see very quickly if it is good or not. Bad oven valves are much less likely than a weak ignitor. Many do-it-yourselfers replace the oven valve because they see the ignitor is glowing and assume that the ignitor must be good.
Hope this helps.
Dec 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
yes replace the ignitor, this is the most common failures of ovens not coming on.
Dec 10, 2007 | Whirlpool SB160PEE Gas Single Oven
GE JGRP17 Gas Single Oven Logo
159 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
