Question about HP Officejet 5610 All-In-One InkJet Printer
New to fax machines...
Hello...we just purchased a HP5610 All-in-one and we have it hooked up properly, but we don't know how to have the fax pick up vs our voicemail picking up?
  • Anonymous Jul 21, 2008
    I don't have a problem with my copier/printer. The problem is me. I just need you to give me step by step instructions on how to scan an item to email to my children, like a picture, etc.
    Thanks,
    Nita Hogg
I can not receive or send a fax
Posted on Jul 22, 2008
How do i get dial tone on fax machine
first, as a tech, i would make sure your phone jack works, then also make sure the line is plugged into the "line" jack on rear of fax. if those two steps are verified beyond a doubt, press your "hook" button and listen for dail tone. if none, pick up handset and listen. if you get tone on handset, then your speaker is disconnected. if you don't get a tone either way, then chances are you have a bad "NCU" board.
good luck,
razors
Oct 19, 2011 | Brother MFC-8220 Fax
Hello, IM having a problem getting my fax machine to pick up the fax
do you have a answering machine hooked up to the same line. If so it may be picking up the line before the copier can
Oct 26, 2010 | HP Photosmart 2610 All-In-One InkJet...
Hpj4580- my phone is equipped with voicemail that picks up after the fourth ring of the phone. How do I set up the fax so that it works with my phone. Currently, when my phone goes to voicemail, the fax...
You need to go in and adjust the "Off Hook" setting so that it does not pick up the ring cycle before the answer machine does.
Next you have to find the instructions that will allow your phone answer machine to tell your fax machine that there is data for it.
More often than not this is accomplished by setting a software switch for example press number 4 to send me a fax. The answer machine in turns wakes up the fax machine and allow the connection to proceed.
It all in those books that came with your products. I know you keep them neatly filed away for instant retrieval, just the the rest of us do. :)
Don
Jan 22, 2010 | HP OfficeJet J4580 All-In-One Laser...
Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
CAN'T RECEIVE A FAX
you can get the manual here: - LINK
Basically you plug your phone line into the fax machine line in and set the ring pick up to the desired length.
When someone calls you the fax should pick up and take the data.
Dec 12, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp 5610 won't receive fax from lexmark fax
Are you able to receive faxes from others from the same location, if not just ask her to consult her service provider and ask to get the no checked of yours why is it that you she is not able to send fax to you only as your fax machine is capable of sending and receiving fax from others it should be dsome issue with her service provider.
If it was your All-In-One printer thrn you should not have received faxes from any one, not a specific number.
Good Luck
Aug 19, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp5610
hello with witch windows do you work???
Jan 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Failed Pick Up
use alcohol and dry cloth and clean all what lubricated,fax machines don`t lubricate!!!!!!!.after cleaning the fax will work properly
Oct 29, 2007 | Panasonic KX-FL501 Plain Paper Laser Fax
MP730 fax issue-can't receive fax, but can send out
I think I know why. You need to set the proper priority of your all-in-one Canon device.
If it is TEL priority, it means you need to have a phone connected to the fax. If the phone rings, you need to pick up the handset and check if it's a fax tone or a call. If it is fax tone, you wait for 5 secs til fax tone stops, and then hang up. After that you will receive the fax. Failure to pick up the handset will not allow you to receive the fax. This might be the most probable setting you have, hence you can't receive the fax.
If it is FAX priority, the same thing happens as TEL priority. Only difference is if you don't pick up, and it is a fax, it will still receive.
You can also do FAX only. No need to connect a phone. Device will receive automatically.
-Acieboy
Sep 21, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Hooking up a fax machine on home telephone line
Well... the problem is that you are running two machines on one line. ONE of them has to take predominance. Both machines should have settings for "number of rings to answer at". It sounds like you currently have the fax set to less than the answering machine, so the fax picks up after two rings, while your answering machine might be set to more, which it never gets to, because the fax answered the call already(It doesn't matter if you answer the phone, or the fax picks up, once the line is open, the answering machine is taken out of the equation). Even if you set the answering machine to answer first, you're then taking the fax service out of the loop. I'm not sure how you're going to juggle that, since both types of machines each need control over the line to work properly. That's why we (business machine folk) always recommend a dedicated line for fax service.
Jan 23, 2007 | Canon FAXPHONE L170 Plain Paper Laser
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
