Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
Hampton Bay outdoor transformer
Thanks for the reply to my question about the high-pitched noise!!!
Is there a way to "reset" the unit? The lights still come on when I use the on/off button. Just don't work on the auto settings. Or maybe it's the sensor? Sorry, but I'm just looking for an easy solution rather than buying a new one. It also seems the unit is hardwired to the house - no plug.
  • GlennMayer1 Jul 24, 2008
    Thanks so much for the reply! I did try one thing. I had switched the locations of two lights and didn't realize the wires needed to be "matched"... Re-wired those two and the unit has been working for the past 5 days. Although, we had some nasty thunderstorms last night and they weren't working, so I'm hoping it's just the GFI reset or a fuse. Thanks again for your responses.
  • 1,512 Answers
Hi
Sorry for the delays in getting back to you. This sort of gear is the "change out" type that is not generally considered repairable. You may need to get an electrician to look at it for you, and offer a quote to repair or replace the offending module. You are probably correct in thinking it is a sensor failure. Good idea to check that light can actually get to it. You could try to reset the device, this will involve powering it right down to provide a hard reset to the control circuitry. Pulling the fuse, or switching the mains down is the best way to do this. Then power up after about 10 mins, and see if then works correctly.
If it does not, then back to a replacement unfortunately. Although not a fix, hope this has helped you to make a decision about what to do with it. FixYa ratings are the only reward we get for providing free advice. Cheers
regards
robotek
Posted on Jul 24, 2008
Hampton Bay 7828 Outdoor motion detector lighting for the driveway
Please an you send a pick of the unit when it's open on the input so we can go trough without Manuel as it's just a lux adjust ment
Sep 27, 2016 | OUTDOOR Home Security
How much is the cost of Hampton bay lighting?
Depends on what lighting you are wanting. Home Improvement Made Easy with New Lower Prices Improve Repair home depot have prices for various hampton bay lighting models.
you can also find information here Hampton Bay Lighting Manuals
Mar 15, 2015 | Hampton Bay Outdoor Lighting. 1-Pack Solar...
My Hampton Bay fan instlled on a slopped cielling on High speed I hear TIC TIC TIC when I rduce speed o MED no more TIC TIC what is the solution. Does the model 459-664 can it be installed on a sloppe
What do you expect to get from a store brand fan? They're cheaper because they use lower end parts. Always look for a fan with at least a 13 degree blade pitch for better air movement.
Mar 28, 2014 | Hampton Bay Dryers
Why not turn the fan on high speed or because my fan does not turn. Is 54WDL Hampton Bay model.
You should never have to use a fan on high speed inside the house unless it's a cheap store brand with no decent blade pitch.
Aug 02, 2013 | Hampton Bay Dryers
My 32" Hampton Bay Minute
Sounds like an excellent idea. In case you don't get a certain reply, i suggest that you remove a blade from your old fan and take it with you to a store that has one on display. Check the spacing of the holes, and the number of blades. You might also find that the width of the blades and their pitch (which is determined by the bracket the blades are attached to) work out in combination to give you about the same performance. But if the bigger fan has a much flatter pitch, you might find it won't deliver as much air as your old fan did with the old blades. Good luck, Al K
Jul 26, 2011 | Hampton Bay 40106 Minute II Ceiling Fan
I have a Hampton Bay 300W transformer. I've attached a 12V bulb to it in the low voltage ports. the LED is covered and the unit is in the on position. About every ten seconds the units flashes the light,...
the Hampton Bay 300W transformer requires that at least a 20 watt load for it to function. If you only have one bulb, say a 10 or 15 watt to test it, it wont work - sounds crazy, I know.
If you have an installation brochure it's under "Important Safety Feature". The first sentence reads "In order for this Transformer to operate, a minimum load of 20 watts MUST be installed before plugging the Transformer into the electrical outlet.
Hope that's it - by the way, these transformers can emit a high pitch when running - not sure why, but it's a common complaint.
Jan 13, 2009 | Computers & Internet
Can't find light kit to fit 52" Hampton Bay ceiling fan
I've found that Hampton Bay has it's own light kits, available only from them. The others (generic) aren't the same size. Hampton Bay fans are made exclusively for Home Depot. They are made by a few different manufacturers but only Home Depot sells them. I would have Home Depot customer service get a brochure for you so you can order what you need, if they don't stock it.
Dec 31, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Just moved into a house that has low voltage outdoor lights. They were working a month ago, but not sure what's happening now. Checked transformer. Lights work in the "on" position, but...
Hi GlennMayer1
The high pitched noise you here is the switchmode electronic type power supply/control electronics malfunctioning. This could be caused by component failure in the power supply or a short circuit in the wiring preventing it from firing up correctly. Hard wiring a lamp directly to the power supply would allow you to check the system, but a replacement power supply is probably required.
regards
robotek
Jul 15, 2008 | Universal Remote Control Hampton Bay...
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
788 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
