Question about Panasonic KX-FL501 Plain Paper Laser Fax
Printing report or making copy
Printing an incoming fax no problem, but printing a report after a fax was sent the text is not readable. The same occures when making a copy.
What could the problem be? Can you please describe for me how this works and what can I do?
    Genius:
  • 2,120 Answers
Lift up the operation panel and look for debris on the small glass strip.
If that's clean, you might have a defective thermal head.
Posted on Sep 05, 2008
How do we set Samsung pro express M4580FX to do auto fax sent status and confirmation after each fax is sent (rather than printing reports)
dear
the sent report can be disabled at FAX SETUP.press menu and scroll to enter fax setup scroll to display report enter here to enable or disable the report. the sent report only display for short time after sending the fax. also you can take a print of journalreport.
Thanks.
Mar 02, 2015 | Samsung Office Equipment & Supplies
Fax transmission reports
What you are explaining should work. If you need prior activity reports from previous faxes, you can press Function then 2 (Act. Report)
I think you might need to press Function, then 7 then 1
From the manual:
Transmission Verification (Xmit) Report You can use the Xmit Report as proof that you sent a fax. This report lists
the time and date of transmission, and whether the transmission was successful.
When the feature is OFF, the report is printed automatically only if an error occurred during transmission. If the report indicates NG, send the document again. If the report indicates you should check the readability of certain pages, resend those pages.
If you typically send multiple faxes to the same destinations, you may need a reminder to identify each fax transmission. You can select OFF+IMAGE or ON+IMAGE to print a portion of the first page of the fax message on the report.
1 For the FAX, press Function , 7 , 1 .
For the MFC, press Function , 1 , 7 , 1 .
2 Press or to select OFF, OFF+IMAGE, ON or ON+IMAGE and press Set .
3 Press Stop to exit.
Hope this helps you.
Mike
Nov 14, 2007 | Brother MFC 8300 Laser Printer
I have done fax text report, cleaned the head and everything has passed. Still no fax received.
Wether its printing any thing? if is printing no need to clean print heads.
check telephone line, if its working, connect the telephone line in line in jack..dial the number check unit it ringing, check out going fax, is it dialing?..if yes check send/receive setting
No incoming/out going replace LIU card..
Sep 09, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
Text is not printing clearly.
Change the photoorganic drum and the cleaning blade,if the cartridge is refill 2 or more time change the cartridge.
Sep 07, 2009 | Office Equipment & Supplies
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Display says "printing online" but it is not connected to a PC
unplug machine, press and hold down the "stop/exit" key while pluggung back in. continue to hold the button down for 5 secs, then release. if machine returns to the regular date/time display, you should be alright. if not, then you'll have to call brother or an authorized service center. this is usually caused by a fax stuck in memory, which this procedure should clear.
good luck,
razors
Feb 11, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
FIRST PAGE PRINTING AFTER SENDING FAX
Scroll through the menus for REPORT PRINT to set confirmation.
Jan 27, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Printing a sent fax
in the settings of the fax there is a setting in reports that you have to turn on conformation with print out.
that gives you time date and 1/2 of the top page of fax sent
May 20, 2008 | HP LaserJet 3050 All-In-One Printer
NOT PRINTING SENT FAX REPORT
Make sure your in fax setup your message confirm is ON and not on ON-ERR. The Sf-560 also has an issue with the phone jack on the back becoming loose and causing sataic. Needs to be resoldered
Mar 26, 2008 | Samsung SF-560 Plain Paper Laser Fax
Panasonic KX-FL501 Plain Paper Laser Fax Logo
105 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
