Back to:
Tags:
Fuji FinePix S3 Pro Digital Camera
Fuji S3 Pro
posted by gettellio on Jul 17, 2008
I hadnt used my fuji s3 Pro for a while ( 3 Months) and when I went to use it... the I put fresh batteries in it and I keep getting low battery and error message, can you help me?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 17, 2008
Not Rated (0)
Blagmeister
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
Sounds like you might not be using the right type of battery. I had a Finepix A820 which did exactly the same thing so I went out and bought some rechargeable 2500mAh NiMH AA batteries and the problem was solved instantly.
Even special batteries designed for use in digital cameras did not work. Only the rechargeable ones did the trick.
Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Fuji S3 Pro:
I don't want to Accept this solution
Can you Help with these Digital Cameras problems?
I've had this camera fully serviced a year ago by fuji...
When I look through the viewfinder it is very dark. When I...
Any issues with this camera randomly shooting and flash...
The video port does not work or is "jumpy" ...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
