Question about HP Photosmart C3180 All-In-One InkJet Printer
Continuous error message
HP cue status has encountered a problem and needs to close. How can I get rid of this message which continues every day.
  • 3 more comments
  • impens Jul 18, 2008
    HP Cue discovery was not listed in my programs.
  • mashasha Nov 21, 2008
    I'm ving the same problem but HP cue was not listed in the programmes installed.
  • mashasha Nov 24, 2008
    Everytime booting my pc the errormsg ClereUIWindFrame:hpqSTEOB.exe diplay.
  • Anonymous Dec 12, 2008
    hp cue-scanning flow component has stopped working
  • mashasha May 11, 2010
    I've got the same problem but there's no HP cue discovery installed.
If there's no HP cue dicovery installed what else to romove since there's hp printers installed.Sbu
Posted on Nov 21, 2008
  • 26 Answers
Delete the hp cue discovery on your add/remove programs
Posted on Jul 18, 2008
Hp cue status root has stopped working
click on the start button go to start search bar and type services.msc and hit enter now a window will open look for hp cue in that and check status it should be started and automatic not mannual or automatic delayed if its started then there is a problem with the cue version of the hp software
now try downloading the driver through the link and reinstall the software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3311800&lc=en&cc=us&dlc=en〈=en&cc=us
Jul 10, 2009 | HP Deskjet D1455 InkJet Printer
Hp CUE Status Root has stopped working ERROR
You should try using Windows Restore. Restore the computer back to when it worked correctly. Then try downloading the latest software for your scanner, etc. from the appropriate websites. i.e. support.hp.com
etc...
That's probably the easiest way to do it.
Feb 20, 2009 | HP Pavilion dv9700t Notebook PC
i had this prob. the "hp cue root " error isnt a hp thing, its a microsoft thing. i beleive it was caused by installing a older model printer AFTER installing a newer model. (i had a hp 2500 series,then installed drivers for a hp 1400 series)
just go to control panel, then "programs and features" , then uninstall everything that is assoiated with the printer your no longer using. just deleating the older printer from the "printers" folder won't do it. (this is assuming that you dont need both printers)
I havent gotten the error message since i did this. besides, its a good rule of thumb to not have drivers that you dont need on your machine anyways.
hope it helps
mkyckrv1
Feb 07, 2009 | HP Pavilion dv6000z Notebook
HP PhotoSmart C4440, All in one will not scan image to computer. I receive an error message stating: HP CUE - Scanning Flow Component has encountered a problem and needs to close. Details from error...
I did not find a "solution" to the HP CUE - Scanning Flow Component problem. However, I did find a work around the problem. I use my graphics editing program to Import/ Acquire/ From Twain and this will allow me to scan from the printer to my graphics program. I can save the image from there.
Better than not being able to scan to my pc at all ...
Sep 26, 2008 | Office Equipment & Supplies
I am using a HP 2610 all in one printer on Windows XP and continue to get the following message at startup: HP Digital Imaging Monitor {CUE} has encountered a problem and needs to close. AppName:...
ok..my recommend
remove all software with add/remove program
go to www.hp.com and get fresh set of complete drivers for your model by operating system
re install
try it again
Aug 20, 2008 | HP Office Equipment & Supplies
HP CUE Status Root Error
It appears to be a problem with HP Cue Device Discovery Service, the tray notification that tells you when your ink is low, etc.  I solved it on a Vista machine by taking Cue out of the Startup tab in msconfig.  (Could show up as HP Cue Device Discovery Service, or  hpqtray08.exe.)  Note that this will also disable the tray icon and its automatic notifications.  All it does is take Cue out of the startup list, but we don't see the error any more and it hasn't affected the printer's functions.
HP has further advice on deeper "cleaning" for the error: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=bpy20854
I haven't come across anything other than manual methods of getting rid of the error.  No updates or patches that I've found.
Aug 15, 2008 | Office Equipment & Supplies
HP Cue Status Root has encountered a problem and needs to close.
ça m'etonne plus que chez HP ils licencient un max , c est une réponse à la con et le mec y ferait mieux d"aller à la peche que de te repondre des conneries pareilles .
sous Vista.
methode rapides .
1 /Panneau de config
2 / outils administration
3/désactiver le service HPCUE
et voilà tu ne seras plus embeter parce truc de merde .
il doit avoir une autre solution pour virer définitivement ce probleme , on verra plus tard fais dejà ça et ton pc va demarrer normalement et plus vite .
Apr 15, 2008 | Office Equipment & Supplies
HP Photosmart C3180 All-In-One InkJet Printer Logo
347 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
