Question about Fantom Computers & Internet
Water Damage I took a plastic cover off my drive Firewire drive and the connection for the power and light button got disconnected. I was wondering where it plugs back in. If someone has a diagram that would be great. The code on the back of the drive is 118715. Thanks
  • 129 Answers
It will only plug in in the correct way. Study the connectors and you will see it.
Posted on Jul 20, 2008
The blue light keeps flashing on and off on my Seagate 4Tb XHD. It won't show up on the finder as connected. What causes that?
follow these steps:
  1. Make sure the computer and external hard drive are powered on.
  2. Safely remove the drive from the computer (if possible).
  3. Disconnect the external drive's USB or FireWire cable.
  4. Disconnect the power supply plug from the external drive.
  5. Power off the computer.
  6. Disconnect the computer's power supply cord for 60 seconds.
  7. Reconnect the computer.
  8. Power on the computer.
  9. Connect the power supply to the external drive.
  10. Connect the drive's USB or FireWire cable and check for detection.
If that does not correct the behavior, and if the drive is also not detected by your computer, the blinking light is probably a symptom of a larger problem. If those steps do not return the drive to correct function, it is very possible, even probable, that the drive has failed and needs to be replaced
Dec 22, 2014 | Seagate Computers & Internet
Motherboard aux power light is flashing
If you mean the power button just flashes green but it does not power on then your motherboard might be the issue. Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. In other words just have the power supply and motherboard connected and see if the power light stays solid green. If it does then start re-inserting cards and connecting drives etc (WITH POWER DISCONNECTED) to try and isolate the problem. If not then your motherboard is probably defective and needs to be replaced. Also plug the computer directly into the AC wall outlet.
Nov 16, 2012 | Dell Dimension E521 PC Desktop
How to replace water inlet valve on a hoover 500M washing machine?
To replace your Hoover washing machine water inlet valves watch this instructional video http://youtu.be/78D5ieegS98
Or follow the instructions below
Turn of the power at the power point and disconect cord.
Turn of water supply to the machine.
Disconnect the water hoses
Unscrew the screws on the rear cover and remove
Use a screwdriver to press in the inlet valves plastic locking clip
Pull the inlet valves upwards and disconnect spring clip electrical terminals
Push in new inlet valves and connect spring clip electrical terminals
Reinstall plastic locking clips
Reinstall rear cover and reinstall screws
Reinstall water hoses and turn water on
Reconnect power cord and switch power on
Aug 02, 2012 | Washing Machines
Mac cannot see 750GB maxtor 4
Did you disconnect the firewire drive before installing? You may need to update your firmware. Also, try these things:
1. Shut down and disconnect your firewire drive leaving nothing is connected to the firewire ports.
2. Restart, and use Disk Utility to repair permissions on your internal.
3. Shut down, and disconnect the AC power from the computer and your drive; also remove battery if laptop.
4. Let computer sit unpowered and disconnected for15 minutes.
5. Reconnect AC power to only the computer and reinsert battery.
6. Restart computer.
7. Verify that firewire ports are visible using System Profiler.
8. Reconnect your firewire drive, and refresh window in System Profiler to rescan the firewire bus, and confirm that drive is visible.
9. Repair disk and permissions on the firewire drive.
Dec 13, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
How to disconnect the water and electrical, and remove the left door of a side by side G E
This should not be very difficult. Unplug refrigerator. Remember that any water remaining in water tank inside the fresh food section will once the line is disconnected at lower left hand hinge area will pour out by gravity once the snap connection is disconnected. Allow the water to flow into a pan until empty. Then unsnap the electrical pin connectors at bottom and top hinge under the cover if present. You may also need to remove the kick plate at base of the refrigerator to be able to reach some of these connections. Most water connections you will need to push the outer ring in to loosen the line. Use care as not to damage the water lines then remove hinge screws being careful to remember location and position of screws washers and plastic hinge covers. If you need more answers please let me know, Thanks Sea Breeze
Jan 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Removal and installation of the water pump
3.0L or 3.8L engine?
please rate as fixed if this solves your issue.
Section 03-01B: Engine, 3.8L 1996 Windstar Workshop Manual
IN-VEHICLE SERVICE Water Pump SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fuel Line Disconnect Tool Set T90T-9550-S
Removal
  1. Drain engine cooling system. Refer to Section 03-03 .
  1. Loosen drive belt tensioner (6B209) and remove drive belt (8620). Refer to Section 03-05 .
  1. Raise vehicle on hoist. Refer to Section 00-02 .
  1. Disconnect lower radiator hose (8286) from radiator lower hose tube (8291) and radiator (8005).
  1. Disconnect radiator lower hose tube from water pump (8501).
  1. Remove lower nut on both front engine support insulators (6038).
  1. Lower vehicle.
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove generator (GEN) (10346) from power steering pump support (3C511).
  1. Position drain pan and disconnect power steering pressure line from power steering pump (3A674) using Fuel Line Disconnect Tool Set T90T-9550-S.
  1. Remove power steering reservoir filler cap.
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: If using a prying device to assist in water pump removal, be careful not to damage the mating surfaces.
    Disconnect water bypass hose (8597) and oil cooler hose (6B850) from heater water outlet tube (18663).
  1. Remove retaining bolts and disconnect heater water outlet tube from water pump.
  1. Remove A/C bracket brace.
  1. Attach engine lifting eye to left-hand (front) exhaust manifold (9430).
  1. Attach lifting equipment to engine lifting eye and raise front of engine approximately 51 mm (2.0 inches) to provide necessary clearance for water pump removal.
  1. Remove water pump pulley retaining bolts and water pump pulley (8509).
  1. Remove drive belt tensioner pulley retaining bolt and drive belt tensioner pulley (6B217) from power steering pump support.
  1. Remove power steering pump support retaining bolts and nut. Place power steering pump and support assembly aside in a position to prevent fluid leakage.
  1. Remove water pump retaining bolts and nuts and water pump. Discard used water pump housing gasket (8507).
Installation
  1. NOTE: Lightly oil all bolt and stud bolt threads before installation except those specifying special sealant.
    Clean gasket surfaces on water pump and engine front cover (6019).
  1. NOTE: The threads of the No. 1 engine front cover retaining stud must be coated with Pipe Sealant with Teflon® D8AZ-19554-A or equivalent meeting Ford specification WSK-M2G350-A2 before installing.
    NOTE: Gasket and Trim Adhesive D7AZ-19B508-B or equivalent meeting Ford specification ESE-M2G52-A is recommended to hold the water pump housing gasket in position.
    Position a new water pump housing gasket on water pump housing sealing surface.
  1. Position water pump on the engine front cover. Install retaining bolts.
  1. Position power steering pump support and install retaining nuts and bolts. Tighten bolts and nuts to 40-55 Nm (30-40 lb-ft).
  1. Install drive belt tensioner pulley and retaining bolt. Tighten bolt to 70-95 Nm (52-70 lb-ft).
  1. Install A/C bracket brace.
  1. Position water pump pulley on water pump hub and install retaining bolts. Tighten bolts to 8.0-11.5 Nm (71-101 lb-in).
  1. Lower engine and disconnect lifting equipment from lifting eye.
  1. Remove lifting eye from exhaust manifold.
  1. Connect heater water outlet tube to water pump and install retaining bolts. Tighten bolts to 8-11.5 Nm (71-101 lb-in).
  1. Connect water bypass hose and oil cooler hose to heater water outlet tube. Tighten clamps securely.
  1. Connect power steering pressure line to power steering pump fitting.
  1. Install power steering reservoir filler cap.
  1. Install generator to power steering pump support. Refer to Section 14-02 .
  1. Connect battery ground cable. Refer to Section 14-01 .
  1. Install lower nut on front engine support insulators and tighten retaining nut to 88-119 Nm (65-87 lb-ft). Install lower nut of rear engine support insulator and tighten to 77-104 Nm (56-76 lb-ft).
  1. Connect radiator lower hose tube to water pump. Install retaining bolt and tighten securely.
  1. Connect lower radiator hose to radiator lower hose tube and radiator. Position hose clamps securely. Refer to Section 03-03 .
  1. Lower vehicle.
  1. Position drive belt over drive belt tensioner and release drive belt tensioner. Refer to Section 03-05 .
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: This engine has aluminum cylinder heads (6049) and requires a special corrosion inhibiting coolant to avoid cooling system damage. Refer to Section 03-03 for the coolant specifications.
    Fill and bleed cooling system with specified coolant.
  1. Fill power steering pump reservoir with specified fluid.
  1. Start engine and check for coolant and power steering fluid leaks. Service as necessary.
    Water Pump
Apr 13, 2009 | 1996 Ford Windstar
Flashing "Washing" light on my frigidaire 1000 series dishwasher
Possible solution. I had the same problem of "washing" light flashing last year and now today. Warranty has been expired for awhile, so no harm in trying. What worked for my situation was removing the six screws for the back of the plastic control cover. Take of the plastic cover. There are are two connectors to the HANDLE with white and black wires. To be safe I would shut off the ciruit to the dishwasher. Safety first. Carefully disconnect and inspect the contacts inside the connectors. Do not insert any metal objects if you left the power on. I believe that the moisture from the dishwasher can degrade the connectivity. I cleaned the contacts with q-tips and re-installed. Be careful to not bend the contacts. If you had sound, you could hear my dishwasher running. Total cost is about three cents. I believe that the connectors do not full close when corroded, which prevents the completion of the circuit to the controlls. The flashing light indicates that the door is open, when in fact it is closed. Hopefully this will help someone. Semper Fi
Jan 02, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Kemore Elite HE4 Dryer
Hi! juysu
Please check the power cord, by checking if there is 240V on the power terminals inside the back of the machine where the power cord is connected.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool refrigerator ice despenser
To All With This Same Problem ,
Remove the top freezer door hinge cover ( 1 screw holding it on ) , and disconnect the plug there . This will disconnect the power to the door dispensor .
Using a butter knife or small screwdriver , insert it in the bottom of the dispensor cover between the grill and the cover .
Push down and in wards , to force the bottom of the cover outward , being careful not to break the 2 or 3 built on plastic clips on the cover .
After the lower portion has been disconnected , lift the cover up to disconnect the top clips and then remove the plug on the cover .
The white piece on the dispensor now visible , is the bracket control .
The switch on the right side , is for water , the switch on the left side , is for ice . Usually , the ice switch , has a broken " spear " , which holds the switch in place . The whole bracket control , pt # 2180226 , will have to be replaced . Only 2 or 4 screws hold it on .
This part is easily replaceable by the consumer .
Just be careful when installing the switch , not to break the new " spears " and be sure to reinstall the plastic " spacers " in the same spot on the new bracket .
When reinstalling the dispensor cover , slip the top on first , and just lightly " pop " the bottom back in place .
Jun 19, 2008 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Power Button does not push in and out
http://www.richspsxparts.com tells you how to disassemble the game console and replace the old switch this also sells new switches
Jan 21, 2008 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
69 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
