Leading cause of paper jams is debris/foreign objects
that accidentally fell into the paper feed area.
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also
turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the
table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris
that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet
to reset it.
8. When the printer turns on, reinsert the cartridges and
load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge
first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge.
Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
I had the exact same problem. I disconnected the printer and then when I flipped it upside down, I heard something drop out of it. Low and behold was my missing letter opener. I then tested the printer to see if it works, and sure enough it feeds properly. Try cheecking to see if any objects may have accidentally fallen into it.
