Question about Video Game Consoles & Games
The power slide on the nintendo ds has no spring back. the slide floats freely and does not turn on the power.
  • 61 Answers
You will need to replace the power switch, check ebay they sell them, also under repair nintendo ds lite for $40.00 if you do it yourself you will have to do some soldering
Posted on Jul 18, 2008
How to turn on your ds lite without using the power button
You could try using a pin and slide the little black tab inside the DS where the power button was.
Jul 18, 2010 | Nintendo DS Lite Console
Power slide {torbo}
idk no eithr ......................omgggez
May 28, 2010 | Nintendo Mario Kart for DS
My 84 YZ250 had the throttle lock up - like full throttle with no change by throttle grip - had to turn gas off at shutoff valve to get it to stop - any idea .......... other question - is the throttle...
There should be a small air gap at the bottom between the slide and the venturi. A couple things to check are (we'll start easy and progress from there):
Remove the carb from the air box and the intake boot, but do not remove the top screw cap or cable from the carb. Once you are holding the carb in your hand, twist the throttle and see if the slide moves up and down freely. Does it return to the botton of the venturi on it's own when the throttle is released (or you twist the throttle forward)? If not, and the slide is sticking open, it is allowing more fuel/air in which is the problem. There is a spring under the top cap which should push the slide back down when you release the throttle. If it's sticking open, it's either a broken cable (you wouldn't see the slide go up and down when you twist the throttle if it's broken), or an unlubricated cable, a piece of debris in the carb between the slide and the carb body, or the spring is whacked. Unscrew the top cap, slowly pull the cap, spring, and slide up and check the spring. You can't miss it, it's a big one right under the cap. If it looks ok, check for debris on the side of the slide and in the carb body to see if there is sand/dirt causing the slide to stick open. If all of this checks out ok, then check the cable for free movement when you twist the throttle. If it's sticky, lube the cable. If it's ok, move to the next step.
On the bottom of the slide you will see the jet needle. It's long, skinny and tapers at the bottom. Try moving the needle up and down. It should be pretty snug. If the "c" clip that holds the needle came off, it will sometimes allow the needle to remain open which will cause this problem too. If the needle is ok (in place nice and solid and doesn't move up and down freely), then go to the next step:
Remove the float bowl and check to see if the float, float valve (under the back edge of the float where the float attaches), and seat (where the valve rests in the carb body) are all in good shape. If the float has a hole in it, or the tang holding the valve clip is bent, it will cause the float to drop down lower in the bowl, which opens the valve and allows more fuel in. Also check that the clip that connects the valve to the float did not come loose. If there is a problem with the float or float valve allowing too much fuel into the bowl, the excess fuel runs into the engine (via vacuum when the engine is running) and will cause the problem you are seeing. In this instance though, there is normally excess fuel coming out of the overflow hole on the side of the carb when the bike is not running and the fuel is on. If your problem just happened once and you shut the fuel off (and haven't turned it back on yet), put the float bowl back on, reinstall the carb and try opening the petcock (gas shut off valve). Let it sit for a few hours or overnight with the gas on. If the float or float valve is bad, you should see gas drip out of the overflow on the side of the carb. You may not have seen this if the problem just started happening while the engine was running. It was sucking the excess fuel into the engine causing it to rev wide open. When you shut off the gas flow, it prevented having the excess fuel drip out the overflow hole and letting you know it was a float problem. Hope this helps.
Nov 19, 2009 | Yamaha YZ 250 Motorcycles
My nintendo ds is charging when I plug the AC adaptor but when is turn it on.. it doesn't start at all.. could someone tell me what's the problem in my DS
give nintendo a call or go to your retailer where you bought it if you bought the warranty youll get a FREE new one hope it helped vote thumbs up for more answers
Aug 09, 2009 | Nintendo DS Lite Console
Power Button Sticking on Nintendo DS Lite
when you slide the power switch try sliding your finger off
Mar 14, 2009 | Nintendo DS Lite Console
DS Lite - broken on/off button
Why don't you go to the nintendo website they can help you, you can explain your problem, ship of the DS and get it back fixed.
Mar 09, 2009 | Nintendo DS Lite Console
Nintendo ds. how do you put little springs in left and right . the right way.
you are probably trying to put the springs on the backing plate but that is not right.
lay the console face down and put the pins in the holes right above the circuit board ( you can put the buttons down on the console and it will show you the proper holes) and then slide the first hole of the button on the pin, put the spring in between the two holes on the button, then slide the button all the way down on the pin and use a small screwdriver to push the spring into the slot that is used to put pressure on the spring.
E-mail me if you need a picture.
ninja_freak318@hotmail.com
Dec 26, 2008 | Nintendo DS Console
Broken power switch
Look on the well known auction sites. Some are selling the switch. Ask them if they could also replace it for you. I could do it for you but I'm in Europe, so a little to far
Nov 17, 2008 | Nintendo DS Lite Console
Power button loosely slides
Yes. The switch has broken and is replaceable. However I wouldn't recommend you do it unless you've done this before. DS Lites are easy to damage further when taking them apart. It's a great system but is easily broken beyond fixing. Look at all the posts on here from people putting new shells on and now the system won't boot up, broken ribbon cable connectors, etc. If it's under a year old contact Nintendo and they will repair it for free.
Mar 08, 2008 | Nintendo DS Lite Console
My Nintendo microphone
My Nintendo ds lite also would not respond to voices. I have brain age 2 and Zelda. In the Zelda options there is a mic test. This will show a graph bar that measures your voice. Well the mic was not working at all for either game. I simply took out the battery and held the power slide for a couple seconds. Amazingly the mic works now for both games. I do not know if moving the power slide is significant, but on computers to de-static them you remove all power sources(battery and ac adapter) and hold the power button for 10 seconds.
Oct 30, 2007 | Nintendo DS Console
Video Game Consoles & Games Logo
286 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
