Question about Canon PIXMA iP3000 InkJet Photo Printer
Printer does not power up
My Canon IP 3000 Pixma does not power up. Have tried to unplug etc. but that does not work.
  • 1 more comment
  • hillary_le Jul 24, 2008
    my pinter have the same problem
  • sally28 Oct 27, 2008
    I also have the same problem. Have seem one for sale on ebay with this problem also.
    I am very upset as I have loads of ink for this printer.
    Sally
  • Anonymous Nov 20, 2008
    Happened to mine also. Power supply cord is fine, tested on another appliance. Light comes on for split second, then turns itself off, and the printer is back offline.
    What to do ?
My Canon IP3000 would not turn. It turned out to be the Print Head. It had burnt out and gone short circuit. This caused the built in power supply to shut down, hence, the printer appears dead.
Now, how do you get the Print Head out when it is locked down on the left side (your right side if facing the printer)? Open the top lid and inside you will see a chrome sharft, about 10mm in diameter, that the Print Head slides along. Put you finger under this bar and lift it 3 to 4mm. It's under spring tension. The Print Head will also rise, releasing it from the lock. With your other hand, slide the Print Head to your left. You can now release the bar and move the Print head freely.
To confirm the fault, try to power up the printer with the Print Head removed. Don't forget to put the lock bar down first, to stop it hitting the cover when it tries to go home.
Posted on Nov 28, 2008
How do you take out the printer head?
Posted on Nov 16, 2009
My printer power wont turn on when i press button
Try removing your printer cartridges and then the print head from the printer. If the printer powers up with the print head removed, then the print head is either shorted or clogged. If it's shorted out then you will need a new print head (usually cheaper to just buy a new printer). If you can clean the print head without damaging it, sometimes it will work again. Usaully a good 24 hour soak in alcohol or a cleaning solution will work.
May 09, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Installed printer will not print
I found a vista driver for a Pixma ip 2600 and downloaded it. My printer now works but the black ink doesn't. Don't know if it's a driver issue or otherwise. It might be worth a try for you. There are no available vista drivers for the ip3000.
Aug 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
How to reset pixma ip1980
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jul 11, 2009 | Canon PIXMA iP1800 InkJet Printer
I have my canon pixma 1980 series... error says ink absorber is full and need to reset... please give me a resetter software.... thanks
Manual reset for canon pixma iP 1980 it easy and like resetting canon ip 1880.If found problem in your printer canon iP 1980 maybe this methode can be use. This reset manual be used to reset waste ink counter in canon pixma iP 1980.
Here how :
  • Turn on your printer Canon Pixma iP1980
  • now Press and hold Resume button for two (2) minutes and then release Resume button.
  • Turn off the printer and turn on again, the Printer will back to normal again.
May 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
No print
Hi there you can try this.
Canon IP 2000 / 3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
All the best Pineworks
Feb 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon pixma ip 3000 power problem
The cord is a tough one. but it has to be pushed in very hard in some models. are you sure it is plugged in at the back of the printer hard? push extra hard.
Feb 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip 3000 photoprinter not working
things to check.
1. check for any paper that may have jam inside the printer.
2. check for open covers, back, top covers and close them properly.
4. check your power adapter if its giving correct voltage to the printer.
3. Try to move the ink cartridge to the left gently and return back to the right most part.
please let us know if this works.
Feb 07, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Lost my set up disc for my Canon ip 3000 printer
Sir,
Click this link to get ur software / driver
Thanks
good luck
Nov 26, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
397 people viewed this question
old marine
old marine
