I have tevion dvdmaker usb 2.0 hardware and am trying to install on my new system and cannot find the software cd.
You need an updated driver. Available from www.unisupport.net.
Posted on May 21, 2009
How can I send designs from my PC to my Toyota 830 embroidery machine when my Pantograms software/hardware is no longer working?
Some of the Pantograms software programs require a USB dongle connected to the computer. However, the driver for this dongle has to be installed before you install the software or connect the dongle. I suspect you may not have installed the driver or the dongle is missing.
Assuming that the dongle is connected:
Close your embroidery software program and all of the Pantograms software, including the Network C software, on your computer and remove the USB device. Put the software install CD into your machine's optical drive. (If your new machine doesn't have an optical drive, get a USB optical drive or copy the files from the CD to a 1GB+ USB flash drive at another computer with an optical drive.) If Windows XP starts the autorun routine for the CD, click Exit. Then double-left click on My Computer to launch File Explorer. Go to the CD drive (or USB drive if you used the work-around) and double-click on it. Open the Rainbow Drivers folder and then open the XP folder. Double click on the program: setup.exe . Choose Complete install as the program executes. Then close File Explorer when the install is done. Now insert the USB dongle and follow the on-screen message about New Hardware found to install the Rainbow driver from C: .
If you do not see the New Hardware found message, try putting the dongle into a different USB port. (Make sure to avoid USB hubs - they can add to USB device issues.) If the dongle doesn't work at any port, you may need to use a different method. There is a flash reader available for connecting a USB flash drive to the Toyota 830 here: http://www.plrelectronics.com/lab/usb_reader.php . (Scroll down to the Toyota machine section. This isn't cheap but it is cheaper than some of the newer embroidery software packages.)
I hope this helps.
Oct 26, 2014 | Sewing Machines
Hw i install this software
There is a cd installer inside of the box along with your webcam. First install the a4tech cd installer and after installing plug your a4tech webcam into your computer usb port.The system will detecting a new hardware just click next or accept or ok to install the detected hardware. If the system requesting for a system restart just restart your computer. Have a good day!
Dec 03, 2010 | A4tech PK-635 Webcam
My 8Gb Tevion USB drive shows No Media
Try this , it has worked freat on my drives
Super Stick Recovery Tool V1.0.2.19.rar
http://www.mediafire.com/?81t60ysdvquymsq
Jun 30, 2010 | Electronics - Others
How do i install a high speed usb port in my ibm tp 600e and also is this computer wi-fi compatible
Plug an external High-speed USB device to a free USB port your computer.
Allow the "Add New Hardware" wizard to search your system for drivers. Windows Vista would typically ask for a location for the drivers while Windows XP would give you the option of saving your preference.
However, if the device was shipped or sold with an installation CD/DVD, slot it in the CD/DVD drive and choose to search locations you specify for the drivers.
Ask your vendor for the best location to find the drivers on the CD/DVD. To be on the safer side, install the software on the CD/DVD. In most cases, the drivers get copied to the system and automatically attracts a recognition by the 'Add New Hardware' wizard.
When the Hardware installs successfully, launch the software (if any) to configure your device the best way it suits you.
Hope this helps!
Apr 03, 2010 | IBM ThinkPad 600E 2645 Notebook
Usb audio driver won't install from original cd
Installing USB sound card (any windows)
  1. Do not connect or plug the USB sound card
  2. install the software and driver
  3. restart the computer
  4. connect the USB Sound Card
  5. windows found new hardware
  6. select find hardware automatically.
  7. if windows cant find the driver select browse CD (contain driver)
i have 3 soundcard installed in my computer (XP Pro SP2,Vista Enterprise,Ubuntu Linux) 1 built in and 2 USB.
built in I use for speaker, 1 USB I used for monitor to my DJ mixing software, 1 USB I used for telephone(VOIP)
Apr 02, 2009 | Crosley Traveler Turntable
Pc don't recogise new hardware
It sounds as if your power supply isn't putting out enough to support so many USB devices on your system. If you have an external USB Hub, do you have a power adapter plugged into it?
Mar 28, 2009 | Computers & Internet
Lost software CD
PDC301driver.exe
See if this one works for you!
~Nate1976
Feb 21, 2009 | Polaroid PDC 301 Webcam
I lost the original software for my x73500 all in one printer scanner copier. I have tried to download the driver from www.lexmark.com. My operating system is windows me. Please tell me how to acquire...
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Drivers, Software, lost C.D....come this way!
If you have lost you cd or don't know how to install your printer then all you need to do is download the drivers and software from the manufactures website that suits your operating system and printer.
Drivers and software download areas for brands listed below, just click to gain access and then locate driver for your needs.
Brother Epson Sharp Canon Lexmark OKI Dell HP Kyocera Samsung Konica/Minolta Xerox Panasonic
PLEASE NOTE
When installing drivers/software it is generally a good practice to -
·                                 Delete old/previous installs
·                                 Leave printers USB cable disconnected from computer until newly installed software requests it to be connected.
Nov 29, 2008 | Lexmark Office Equipment & Supplies
Cannot install this hardware
First of all, you might want to read this:
http://www.fixya.com/support/t299686-install_microsoft_lifecam_vx_3000
What system are you using?
Try doing a Google search "LifeCam VX3000 installation" and seeing if any of the documents listed helps you. I am not sure what OS you are using (Windows XP or Vista? Linux? Another?) Others have reported problems too. Be careful about which you do first during setup. Some systems require installing drivers/software BEFORE you plug in the camera, and some require you to install software/drivers AFTER you plug in the camera.
Nov 08, 2008 | Microsoft LifeCam VX-3000 Web Camera
J5780 Installation Problem on Windows 2000 PC
hi this is due to improper Software Installation stapes below
  • Un install all printer driver & software u install
  • disconnect printer from computer
  • restart u r computer
  • insert Software cd in to cd rom
  • install software ,follow instruction & fill up Information.
  • when notify you to please connect printer thorgh USB please connected Usb cable to your Printer.
  • printer shuld be ditected then follow instruction
  • complite Installation & cheak it out..
If this information is useful for u please rate me....
Jun 09, 2008 | HP Officejet J5780 All-In-One InkJet...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
