Question about GE Monogram ZEU30R Electric Cooktop
My cooktop is showing f156 blinking & beeping. ZEU30r. What does it mean? Is t safe. How do I stop this error code?
  • jkotz910 Jan 25, 2011
    The error code is gone. Now I will have to use it and see if it reappears.
  • 1,998 Answers
You haxe a flmction error code. X,_rite down the "F:- - -" and
touch the _) (CONTROl, I,OCK) pad. Disconnect power to
the cooktop and then reconnect.
if this doesnt work then you would have to call for a technician looking like you might have a problem with the control if you have any further questions message me back Thanks Rick if you cant unplug your unit shut off the breaker for 5-7min
Posted on Jan 24, 2011
  • Rick Ead
    Rick Ead Jan 24, 2011
    there is another test also mentioned that says shut off your unit for 30 minutes without power and this may make the control reset but if you haveing a problem with the contol then it would reappear as soon as you were to replug and go back to the same error Thanks again Rick
  • Rick Ead
    Rick Ead Jan 26, 2011
    if your unit is under warranty call them and schedule them to come out and check your unit before anything else happens Thanks again Rick it shouldnt but the 156 code is a communication problem with the control just better to have them double check then have the unit fail when you need it most Thanks again Rick
I have a glass cooktop Electrolux which is only 2 years. stopped functioning with a E-11 error code and cannot ulock. what can Ido?
Hello Gloria Padilla, thank you for your post!
I understand that your Electrolux cooktop is displaying an error code "E-11" and will not allow you to operate. The "E-11" error code stands for key sensor in cook place four. This could mean a possible issue with your flex cable, right board, or left board. I see you have completed a reset on your cooktop, at this point I would recommend having a professional technician for a proper diagnosis to be completed. I hope this information is helpful. -Matt
Dec 29, 2014 | Electrolux Cooktops
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
What does electrolux stove induction error code E21 mean?
Did u ever find out.mine is doing the same.ive searched everywhere and can't find an answer
Jun 23, 2014 | LG range & stove induction cooktops...
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
How to change wb30t10062
remove the cook top from the counter and the remove the glass top, several screws around the edge of box. the lift top and you have access to the elements.
Jan 05, 2012 | GE Monogram ZEU30R Electric Cooktop
I Bought Prestige induction stove I am getting E5 error can any body help what it means
E5 or E0 means that the stove is getting overheated. You have to reduce the temperature for it to stop. It goes on with few beeps and then stops.
Sep 10, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
Ge monogram cooktop model#zeu30rsf1ss error code f1 74
Hi There
I have found the codes that you need and hope this helps you.
F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.Thank You for writing to fix ya.
Best Regards Richard
Feb 18, 2010 | GE Monogram ZEU30R Electric Cooktop
No heat cookop gives me code rf f156 , lf f116, rr f 146, lr f126
You will need a serviceman for this one as it is a serious problem.
note: rr is right rear, lf is left front and so on.
Usually this indicates a problem with the elements or worse - electronics (if it's the electronic version).
Jun 19, 2009 | GE 30 in.JP950 Electric Cooktop
GE Monogram ZEU30R Electric Cooktop Logo
2,590 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Steve Allison
Steve Allison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
