Question about Indesit W 123 Front Load Washer
Washer will not drain
My washer will wash and the dial cont. to move around to the stop position, but when I raise the lid the washer is still full of water and soap.
HELP
  • jchukz Aug 08, 2008
    i took out the washing machine drainage pipe, drained into a bucket, lifted the machine unto a stool to drain under gravity. Retried the washing again it still did not drain.
    Scholar:
  • 97 Answers
Hiya
i take it you have a toploading machine then, have you removed the agitator in the center of the machine there's usually a fluff filter underneath it, this could be causing your problem.
try draining it out manually by putting the outlet hose into a bucket.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Posted on Jul 31, 2008
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Washer will not agitate/spin.
The lid switch is fine. The timer needs to be replaced.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Wash will not drain
Hi, When the cycle goes into drain, do you hear the motor humming at all? If the motor does not hum, check the lid switch.
If the washer agitates, there must be a problem with lid switch ot timer. The lid switch is most common.
Please let me know if this helps or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
Washer stopped after wash cycle
The lid switch is the culprit. Push down on the lid it should start. It needs to be adjusted . the tab on the lid is not activating the switch. Try triming the door bumpers.
Apr 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
HELP
Mar 27, 2008 | Washing Machines
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Indesit W 123 Front Load Washer Logo
48 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
