Question about Eureka Atlantis 2595A Upright Wet/Dry Vacuum
Eureka Atlantis Rug shampooer wont **** up the water, how can I fix it. Thanks Dennee
  • Anonymous Nov 08, 2008
    brushes work n o suction
  • Anonymous Mar 16, 2014
    will not spray shampoo-water
Make sure that the two slide-tabs on the front of the machine are all the way down so that they can hold the front see-through cover down and create suction at the front. I did the same thing. you can tell when they get moved while cleaning because you will hear a muffled pop like something just got sucked into the vacuum. It is just the sound of suction being broken.
Posted on Aug 29, 2008
MY BISSELL RUG SHAMPOOER WORKS GREAT BUT WONT **** UP THE WATER
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Mar 19, 2011 | Vacuums
I need an upper handle release for my Eureka Atlantis 2596A Deep Steam Extractor
i have a vacuum shop in albuq, n.m. and i have a used atlantis release handle if you are close or you would like me to ship it to you , thanks Don the Vacuum Doctor
Nov 04, 2009 | Eureka Atlantis 2591A Upright Steam Vacuum
No suction or spray - Eureka Atlantis Steam Cleaner
I got the machine working. I think because it hadn't been used for awhile that the seals were dried out. I wet them and let it sit for awhile and then I could push the containers all the way in and seated them properly. Then it started working no problem and I got to clean my carpets.
Oct 05, 2009 | Eureka Atlantis 2591A Upright Steam Vacuum
Spray button doesn't function on Eureka Atlantis.No water spray.
should be mechanical, torx screws are easy to remove with a torx screw driver
Aug 05, 2009 | Eureka Atlantis 2595A Upright Wet/Dry...
My bissell proheat rug shampooer wont wet carpet at all
heatman101
gfhjdhg
Jun 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Eureka Atlantis 2590 Deep Steam Extractor will not spray
I cannot find a shampoo canister for my Eureka 2590 Series extractor. They are not made anymore.
Jun 07, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Eureka atlantis...water won't spray out.
Try taking the upholstery nozzle apart, there are only a couple of screws, and make sure the little tube is attached where it is supposed to be attached. Be careful when you take it apart, and remember how to put it back together. Try running some water in the one end and see if it comes out the other end. I had a problem with the grip switch not working, and ended getting Eureka to send me a whole new unit as it was still under warranty. I honestly tried to fix it myself, but I don't think the design is good enough to be fixed, so replacement is usually the better choice. Again, I say, shame on Eureka for such a bad product. A good appliance service depot should be able to get a new hose for you, but if you have to pay big bucks, I think it is better to try a different brand than Eureka. I'm assuming by your question that the nozzle is the one on the upholstery hose attachment.
Nov 20, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
NEED MANUAL OR INSTRUCTIONS FOR DURABRAND DUAL POWER VACUUM/BLOWER
I have an Eureka Atlantis Opti Heat Carper Shampooer Model 2596. I do not have an instruction book. What I need to know is how much carpet cleaner & water to mix together.
May 02, 2008 | Vacuums
Leaking Carper Shampooer
I have an Eureka Atlantis Deep Steam Extractor and it does the same thing. It's not new but it hasn't been used much.
The manual says to "push the tank in until it snaps into place". Everything looks fine across the board so I believe this particular model is just a bad design overall.
My recomendation: Get a new carpet cleaner from Target or Wal-Mart.
Please let me know if this helps. Good luck!
Feb 28, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
No water and brushes not working
Sadly, the advice I got from Eureka was "Time for a new attachment". They can tell where to find a service agent. Call the service agent, and ask if Eureka has solved this problem. Don't waste your time trying to fix it - believe me, it's not worth it unless you are a master with switches, etc.
If Eureka has come up with a new design for that upholstery attachment, the service guy will know because millions are having problems with it (by the looks of it!). I also heard this model was discontinued, but I did not hear that from Eureka when I phoned about my problem.
Jan 14, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Eureka Atlantis 2595A Upright Wet/Dry Vacuum Logo
622 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
