Question about Sony Walkman NWZ-B105F MP3 Player
Broken walkman mine is actually a sony NWZ-B103F but i put it in a MAC and i took it out then i pressed the power button and nothing turned on but i usally use windows with it so do i have to reset it?
Well, my **** just fell off.
Posted on Aug 14, 2008
Sony Walkman NWZ-B162F MP3 Player won't turn off
I was also facing the same problem, and while going with some hit and trials, was able to find a solution for this as following: power can be switched off by holding the main key for long, the key which is used to select the folders, that is, the center of navigation key. Hope it helps.
Jun 13, 2012 | Sony Walkman NWZ-B103F MP3 Player
Sony Walkman NWZ-B103F it wont open..
check the unit after completing each step:
Confirm that the portable player is connected to a working USB port and that it is charging. If necessary, connect it to a different port. When connected properly, the battery icon will be animated or it will indicate the charge status such as FULL when charging is completed. Make sure that you are pressing the POWER button to turn the player on. Previous Walkman® models that did not have a power button would turn on by pressing any button. This model must have the power button pressed to turn it on.
Ensure that the HOLD function is not activated.
NOTE: For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, continue with this procedure to reset the unit.
If the portable player is still not responding, reset it by pressing the RESET button with a small pin or similar object.
NOTE: When the RESET button is pressed, although the unit will retain the music data and clock settings, all other stored data and settings may be deleted. If the unit starts up after the reset, access the Settings menu and initialize the unit using the Format (initialize) function.
If there was no change after the player was reset, connect it to the computer and reset it again, leaving it connected.
Check the Sony Support Web site to see if there are any available firmware updates for your model. Updates can be found on the Sony Support Web Site.
If possible, instead of connecting the USB cable to the computer, connect it to a USB AC adapter (if available) and try to charge it.
Mar 25, 2011 | Sony Walkman NWZ-B103F MP3 Player
My Sony Walkman NWZ B153F is freeze on fm radio. I cannot turn off, do enithing.So? Thanks!
Carlos Barrera Chaupis on Walkman NWZ-B153F:
I used to have the same problem. But the freezing can also happen when you try to turn it on. You may also eventually have problems while trying to copy files from your computer to the device. A little window appears saying the copy couldn't be accomplished because the devise just turn itself off. (?)
Feb 25, 2011 | Sony Walkman NWZ-B103F MP3 Player
Im trying to delete all songs, pictures &&videos from my Sony Walkman MP3 player. i pushed the rest button but nothing was erased. how do i rest the whole Player?
one of the quickest way I know is to plug into computer and ope it like a storage device then just delete what you wish via the computer
I hope this helped you
Dec 20, 2010 | Sony Walkman NWZ-B103F MP3 Player
Error" Power off" walkman NWD-B103F
boot error power off walkman NWZ-B133F sony
Aug 30, 2010 | Sony Walkman Bean NW-E307 MP3 Player
Sony walkman doesnt turn on even if its not lowbat. what shall i do
Buggy firmware. Place a slim blunt object into the reset button on the back and turn on again. This happens regularly for me
Mar 20, 2009 | Sony Walkman NWZ-B103F MP3 Player
Sony Walkman NWD-B103F Problem
MY SONY MP3 PLAYER (NWD-B103F) PROPERLY ON ,OFF . IF PRESS PLAY BUTTON SUDDENLY SHOWN "POWER OFF" AND TURN OFF THEN IT RESTARTING AGAIN
Dec 08, 2008 | Sony Walkman Bean NW-E307 MP3 Player
DRM Error
Connect the player to your computer and remove all your files from the player. Then press the reset button and put the files back to your player.
If the problem persists, please find the firmware for this product and update it.
For more information, contact www.sony.com.
Aug 06, 2008 | Sony Walkman NWZ-B103F MP3 Player
Sony Walkman NWZ-B105F MP3 Player Logo
137 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
