Question about Xerox Phaser 7760/YDX Laser Printer
Printer lines i have a xerox phaser 7760, and there has started all of the sudden lines coming up on some pictures. its not on all pictures and not on all computers on our network. we have changed the volt fuser out, and that fixed it fora little while, but these are documents we have always printed, and they are just now having black lines running horizontally downthe pictures. Can you help me? thanks.
  • drcochran32 Jul 17, 2008
    where is the drum blade
    we have four toner cartridges, none of them have rings around them
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Xerox Master
  • 1,362 Answers
Did you check the drum? it could be coming from the drum blade.
Posted on Jul 17, 2008
  • CheckitRight
    CheckitRight Jul 17, 2008
    open door where you replace toner cartridge, remove toner cartridge, turn upside down, there is a shiny cylinder look at it and see if there is a black toner ring around it, if yes there is your problem, unfortunately you would have to replace the whole unit
  • CheckitRight
    Next step is to check the belt. The big black shiny belt when you open the door. DO NOT TOUCH, get a lint free cloth and wipe, turn the belt ( holding the edges only) and wipe and look for toner or any smudges.
    clean the paper path area ( the route the paper takes, use an air spray can to get crevisses, and clean after.
Fault 004-350
Here is a link for the Phaser 7760 service manual:
Xerox Phaser 7760 Service Manual
004-350 Marking Device Fail (Controller Video)
Mar 23, 2014 | Xerox Phaser 7760 Laser Printer
Tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
on Dec 30, 2009 | Office Equipment & Supplies
Xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 776
When you have a sensor failure, you need to replace the black ATC sensor and recalibrate it. Another reason for sensor failure is you are not getting toner moved down to mix with the developer...the toner tube/auger spring could be clogged up or not functioning.
Also if you changed the developer housing when you changed the developer, you need to change the value to the new sensor # that comes with the housing.
Feb 16, 2014 | Xerox Phaser 7760DN Laser Printer
Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
Xerox 7760 printer doesnt load up
check the operating system of your computer where you upload the printer driver..check its compatibility and check the twain conflicts,try to remove the other brand installed printer or remove any firewall installed on your computer...and then reload the xerox 7760 printer driver...
Jun 07, 2010 | Xerox Phaser 7760/YDX Laser Printer
Phaser 7760 dirty printing
Dear User,
This is a common problem of all laser printers, don't worry i will give you solutions for this. If you can able to remove the DRUM set from the printer and check that any power leak or not, IF yes clean it well and insert into printer again take a printout , afterthat also coming like dirty. So please change the drum and put a NEW DRUM. Your drum capacity is crosed beyond the limit.
I hope that my suggession will helpful to you, if yes please rate this ...
Feb 27, 2010 | Xerox Phaser 7760/GX Laser Printer
Xerox phaser 7760dx
This could possible be the magenta drum cartridge. also try cleaning the ROS assembly window below the drum cartridge.
Jun 10, 2009 | Xerox Phaser 7760/YDX Laser Printer
Xerox Phaser 7760/YDX Laser Printer Logo
458 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
