Question about RCA P52926 52" Rear Projection Television
D52W26 Convergence board
From reading the Forums I believe my Convergence board needs to be swapped. I don't think the RCA D52W26 has IC's to change out the STK's, Wouldn't I need to replace the Board? Can the D52W20 Covergence Board be used to do this?
  • 1 more comment
  • tny_mnl Jul 21, 2008
    Thank you now all I have to do is try and find a good website to purchance the board. lol Thank you again!
    Ok, thanks again. Got another questions.... That convegence power supply board how can you tell if that has been ruined also? I'm pretty sure that just my covergence board needs to be replaced because I do have power.... Thanks for your help ahead of time.
  • tny_mnl Jul 22, 2008
    Outstanding Slinteriors, Again I appreciate your help, and there is only red that is fadding off of the objects in the T.V. thanks once again.
  • RCA Master
  • 8,617 Answers
Yes the D52W20 and the D52w26 are both ITC222 chassis they are exactly the same
Posted on Jul 17, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jul 21, 2008
    You can get the board for the ITC222 at the following link, they are actually pretty hard to find.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    Usually the convergence power supply is suspect when you have more than one color out of alignment and cany adjust them back. If its one color its usually related to the convergence board itself.
  • Sonny Berry
    Sonny Berry Jul 22, 2008
    Your welcome, The convergence board should be all thats needed for your problem with just the one color affected.
My rca d52w26 convergence is gone.
Look in the on screen menu for convergence and if it is not there you have a open ( bad ) protection part on the main board, a kit exists for most of these sets for this===buttons alone will not likely help here.
the convergence menu missing is a result of this and the part in question is often bad because of bad solder connections.
If you need more info let me know.
Aug 28, 2012 | RCA P52960 52" Rear Projection Television
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26- 52 " rear projectio- 3d colors,,,is convergence issue
um i think your gona meet your maker,,,your solutions are not being tolerated.. listen...to the new maker, he can and will make you learn what manners are!!
My RCA D52W26 projection Tv is blurry. Digital board replacement
You cannot replace it yourself sir because there are a lot of adjustments(electronically not mechanical) and you need an equipment to transfer the data from the old EEPROM to the new one. If the convergence is fine then the fuse should be ok..Picture is blurry??? 1. could be a dusty CRT lens, you can clean those 3 lenses by taking off the front speaker grill then there's a small hole that you can see the lenses... or the mirror needs to be cleaned also. 2. maybe it needs a convergence alignment, pls check your owner's manual if available. thanks:)
Dec 28, 2009 | RCA Televison & Video
Who does in home TV repair have an RCA D61W20 or can it be done m
The most obvious item which is causing your problem are the 220K ohm 1/4 watt resistors on the convergence power supply board. There are four of them RP10, RP11, RP12 amd RP13
Jun 18, 2009 | RCA D61W20 61" Rear Projection Television
Rca d52w23 convergence problem error code 84
Go to menu then setup does it have convergence on menu if not then you have a open fuse FL231 it will be the middle fuse there will be 3 of them on right side of FBT flyback transfomer.let me know!
Feb 16, 2009 | RCA Televison & Video
RCA Model 56926. Looks like colors don't converge. Screen looks bowed at top and bottom. I was away when happened, but there was a storm.
hello,
It looks like a convergence problem..So try to replace the Convergence IC if you can or if you ar not quite sure try calling up a service person to do the job for you..Thank you
Regards!!...
Aug 02, 2008 | Televison & Video
Picture problem
If this is a ctc 195 chassis then your likely problem is the convergence power supply that is mounted above the main board and the dynamic convergence board. On the board is an IC (usually) that can be changed: STK 730-010 I believe is the correct number...you can check the number, If it has a single transistor on the metal heat sink, I would suggest changing the whole board. Has only two plugs: one on each end of the board.
Dec 29, 2007 | RCA P52955 52" Rear Projection Television
Rca d52w26
You have to have your tubes re-alined, they sometimes do that if the tv has been bumped or jared.
Oct 17, 2007 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
760 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
