Question about HP Officejet 5610 All-In-One InkJet Printer
Scanner makes whites lines in all scans
I was hopeing to find a fix for this. Anyone know how to fix it?
this is what I get:
http://www.nyankokitty.com/www/scanwhitelines.jpg
  • 1 more comment
  • blackimari Jul 17, 2008
    I do not have problems PRINTING
    I have problems SCANNING
    I get white lines in my SCANNING
    nope the glass is clear. LOOK AT MY PHOTO
    nope didn't work
  • 52 Answers
U clean ur catridge,
in printer setting  only, u will have an option called, clean catridge, then, u select tat option and it will clean, n finally give print test page, and check if u r prob is solved
Posted on Jul 17, 2008
  • 1 more comment
  • ABHILASH V R
    ABHILASH V R Jul 17, 2008
    then, did u check ur scanner surface, i mean, where u keep ur docunents to scan, there might be some obstacle, or scratch or something,
    cause, for the white lines to be generated after scan, there should be some source for tat.. so i think, the source is nothing but the glass surface...
    So check tat, and this is my idea, hope its is correct...
  • ABHILASH V R
    oh, then, sorry, i think i dont hav any other solution,
    but, for my sake, pls try , reinstalling the printer scanner copier software or driver, and check, it once, cause, some times, these type of things just clears our problem...
    And pls let me know if it works
  • ABHILASH V R
    oh, then, sorry, i have no more solutions,
    any ways, hope, ur scanner will get alright...
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
Colored lines on a copy page
To fix the colored lines on a copy page do the below steps
  1. Disconnect the power cord, wait five seconds, and then plug it back in. This will reinitialize the unit and force the scanner to calibrate again.
  2. Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the unit must be serviced.
  4. Verify that the alignment page is placed on the scanner glass or in the automatic document feeder (if equipped) correctly. Place the printed side down.
  5. Make a copy of the alignment page. The unit will make a copy even if the alignment message is displayed. Compare the copy to the original. If vertical lines appear in the copy, check to see if the scanner assembly requires cleaning. If cleaning the scanner assembly does not correct the problem, service the product.
Dec 10, 2010 | HP OfficeJet k60 All-In-One InkJet Printer
The scanner,which has not been used for about 1 year is scanning slides completely black except for 2 white lines,equal distance apart,down the middle,horizontally
Check to see if the lamp is burned out. You should be able top see light inside the scanner when scanning. Maybe the white lines are stray light or a faulty sensor. You can get a repair quote online from Canon. I have heard some people report the repairs were rasonable.
Hope this helps
Dec 15, 2009 | Canon CanoScan FS4000US Film Scanner
We have a red line thru our scans? I have cleaned everything it says to clean?
red line? this is a black & white
is the line apear only when you scan ?
try and make a copy of the glass if you do not see line .than you problem is that **** glass that scanner uses.IT MAY HAVE WHITE OUT OR INK CLEAN IT .it long thin along the the paten glass
hope that help
Nov 13, 2009 | Kyocera Copystar CS-1820 Black and White...
Pandigital mini photo scanner pictures have white lines on them
have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Sep 05, 2009 | PANDIGITAL PhotoLink PANSCN06
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Visioneer Strobe XP 100 - Vertical lines on photos
I lost my software Driver of Flatbed scanner D1250u2f. So, I want to download a new for my scanner. Where Can I get it; can you help for getting it.
Feb 07, 2009 | Visioneer XP100 Strobe Mobile Scanner USB
Scanned pictures are black and white
if the unit makes color copies correctly, the scanner is working correctly, the application you are scanning to sets the size, resolution, color/b&w, etc. you will need to enter into the application and set it for color.
if u have any ?'s let us know, we will Fix Ya.
clarkco
Feb 06, 2009 | HP LaserJet 3050 All-In-One Printer
Scanner Problem Epson Stylus CX4800
Try to clean the scanner glass with a dry cloth...
Try scanning afterwards...if the same issue occurs...
Try to uninstall and reinstall the scanner from your computer..
If you have windows...
Go to add or remove programs and uninstall "epson scan"
Apr 10, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Black Line in scans
You'll have to take it apart and get at the scanning unit (the little light that moves back and forth.  They don't make a manual for that (that I can find) so it'll be a bear to figure out.
But once you get it apart, clean the scanner (lights) and any mirrors you can find.  Then clean the glass.  And look at where the scanner rests when you're not using the copier.  On the underside of the glass, just above this point, you'll see a white strip.  Make sure it's clean.
Oh...this is assuming that it only happens with copies and not with computer prints.
Oct 29, 2007 | HP PSC 1610v All-in-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
