Question about RCA HD52W59 HDTV Projection Television
Part # ?
So what is the part # for fl231?
  • RCA Master
  • 8,617 Answers
RCA part 259213 its a 400ma 125V fuse
Posted on Jul 17, 2008
WERE CAN I BUY AND HOW MUCH IS A FL231 FUSE FOR RCA HD52W59
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 26.00. Its listed under the RCA repair kits as the ITC222 & ITC222A convergence option missing repair kit. Its available at www.tvrepairworld.com
Dec 29, 2011 | RCA HD52W59 HDTV Projection Television
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
Does the rca 52950 have the fl231 fuse? If so where is it located? If not which fuse controls the convergence. I fixed my newer model tv with the fl231 fuse but I dont see it in this tv.
no the fl231 fuse is only for model itc222 rca's . these older set unfortunately do not have that fuse convergence is contolled by a sepreated cuircit board. also these set have no stk ics that are common for most set that control convergence. it uses a series off transistors.
Jan 03, 2011 | RCA P52950 52" Rear Projection Television
Cant find convergence in setup
There are three small rectangles sqaure boxes cap fuses parts(FL231) the one in the middle is dead.Replaced the one in the middle located right side near of the big black block of plastic call FBT.U know how to do soldering and have the equipments?Try website like Ebay.com to the cap fuse part(FL231) fuse.After the cap fuse(FL231) is replaced the Convergence well return,ur tv back to normal.
May 28, 2010 | RCA D52W136D 52 in. TV/DVD Combo
R52WH74 FL231 FUSE
You will need to replace FL231, DL231 and CL230 you can get the parts at the following link with free instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jun 07, 2009 | Televison & Video
FL231 Fuse Location
the fl231 fuse is a small rectangular fuse tan or brown in color. located on the deflection board next too what is known as a flyback transformer. this is a large black componet with two wires coming from the top. one large red one. it looks sort of like a dristibitor of a car ... too the right there is three small rectagular parts these are fuses the one in the middle is the fuse
Apr 04, 2009 | RCA HD52W59 HDTV Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
Fl231 fuse compatibility
yes, thats the replacement fuse for your set. However unless you have replaced the convergence power supply also chances are the fuse will blow again, as the power supply shorting is what causes the convergence to get out of alignment and it will then blow FL231 thereby removing the convergence option from the menu.
Sep 02, 2008 | RCA HD52W59 HDTV Projection Television
Fl231
Its just a regular fuse some models have F231 instead of FL231 it should be just to the upper right side of the flyback.
May 21, 2008 | RCA P52926 52" Rear Projection Television
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
