Question about Ricoh Aficio Colour 3006 Color Copier
Ricoh Aficio 3006 error sc452
Is there a list of error messages for this copier? I am getting SC452 now, last reboot I got SC326 Thanks Kathy
  • Anonymous Jul 30, 2008
    Have Rebooted M/c and error code SC326 shows just before scanning the original
  • 155 Answers
SC326, First of all check that the laser slitglass is still there, I've seen a couple of machines where the slitglass has been missing completely and it's been throwing up laser SCs. Remove the laser unit. Clean all the toner and dust out of it. Clean the synch sensor very carefully. If codes continue replace the LD unit. They tend to fail on these machines due to excess dusting
Posted on Sep 23, 2011
  • 126 Answers
The SC 326 is -- 2nd laser synchronization error. Meaning, the 2nd laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Basically your polygonal mirror motor unit is bad and needs to be replaced. You can replace the whole laser unit but that is expensive. When you replace the PMM unit, do so in a still air area -- as to not get anything in the unit. When you get the PMM unit -- contact me and I can walk you through the steps to replace.
The SC 452 is --- Transfer Belt Mark Detection Error. Once you fix the SC 326 error this one should be fixed also.
Posted on Jan 14, 2009
Ricoh sc452
That error code is related to Paper transfer belt contact motor error
The paper transfer belt contact motor drives beyond the specified time during home position detection or contact operation.Broken harness or defective connectors. Disconnected connector of paper transfer belt contact sensor or motor. Defective paper transfer belt contact motor. Paper transfer belt unit not installed try to change the motor
Oct 24, 2013 | Office Equipment & Supplies
What to do if your ricoh 1022/1027/270/220 copier show SC452
To who had encounted this problem:
1. Don' t panic as the copier jammed temporarily
2. Switch off the copier
3. Open the lateral door,take out the fuser unit & replace the 2 unit termistor unit with the new unit [cost around us30]
4. Insert back the fuser unit then closed the laterl door
5. You have to reset the copier, below is the process:
6. Switch on the copier
7. Push button cancel[yellow] with button 1, 0,7 then follow
on Apr 16, 2010 | Office Equipment & Supplies
What is error code SC326-00 on a Ricoh Aficio 450 copier?
326 error in laser unit . check ld conection and reset yourmachin
Jul 05, 2012 | Ricoh Aficio 450 Copier
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
SC452 Transfer Belt Mark Detection Error
Without the model i think it is difficult to help you any way.
Mar 05, 2011 | Ricoh Office Equipment & Supplies
How to solve error SC452 for colour copier
sc 542 is the fuser error code. please check with a ricoh tech to fix it.
Jan 03, 2011 | Ricoh Office Equipment & Supplies
SC326 is a laser synch detect error. The jamming is probably just because of the code popping up and the machine shutting down. 9 times out of 10 the cause of an SC326 is toner dust buildup on the laser optics. It is either that or possibly a laser unit (LD Unit) failure. The power to the LD unit flows thru the front door switches and I have seen those go bad and cut or reduce power to the LD unit which will cause the same code. I would get a Ricoh tech out to clean the laser optics. This is especially true if you open the fron door and there is toner dusting around the toner cartridge/DV unit area.
Good Luck and Thank You for using Fixya.
Aug 31, 2010 | Ricoh Aficio 1035 Copier
Sir my Ricoh 1045 machine have SC 326 problem, after taking a single copy the error code comes. please give a good solution to clear my problem. thanks
sc326 is a laser synchronization error. The problem is usually caused by the laser sync detection board or the LD unit.
Jun 02, 2010 | Ricoh Aficio 1035 Copier
After sc326-00 my copieur ricoh aficio 350 put on his screen sc322-00 and not work, how cold i resolve this problem
Laser Synchronization Error(1 & 2)(sc322 & sc326)
· Laser synchronization detector board out of position
· Laser synchronization detector board defective
Also check if any cables are loose and also if the laser unit is dirty.-Clean it.
Feb 09, 2010 | Ricoh Aficio 350e Printer
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Dec 21, 2007 | Ricoh Aficio Colour 3006 Color Copier
1,128 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
