Question about Whirlpool LER5636P Electric Dryer
Kenmore 70 series dryer 66712
The dryer will not heat up and nor will it shut off automatically. We replaced a heating element in it in 2007 b/c it would not heat up. That fixed the problem but now this is happening. What could it be now?
  • 525 Answers
Your issue is as follows;
"The dryer will not heat up and nor will it shut off automatically. We replaced a heating element in it in 2007 b/c it would not heat up. That fixed the problem but now this is happening. What could it be now?"
Based on the information provided above, I am unable to access my database to provide you with exacting information. You did not provide a valid model number! However, I have provided some common solutions to help guide you in your search.
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Here are some helpful tips:
If your dryer doesn't heat, check these:
Temperature Switch; make sure a positive heat selection has been made, still no heat, then check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If these tips fail to correct the problem, post me back with a valid model number, (see note in paragrah under "My Solution is"), and I will be able to assist you further.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 17, 2008
Kenmore 70 Dryer won't heat
Hi Jason
There is no fuse to replace only thermostats/thermistors...and heating element.
Here is some things to check:
Apr 25, 2013 | Dryers
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
My Kenmore series 70 electric dryer isn't heating. Replace element, thermostats, ?
a heating element would be a likely cause however before you replace the element you should check to make sure that it is bad by using an ohm meter to check the element for continuity. if you take the element out of the machine you can usually visualy inspect it and see the broken wire.
May 29, 2010 | Kenmore 67632 Electric Dryer
Kenmore series 70 dryer will not heat up replaced heating element thermostats check ok with ohm meter
If heating element was replaced and still no heat, Then what I would do is test the voltage current in the wiring and see if there is actually power to the element.
All parts to make dryer heat are:
heating element
thermal fuse
thermostat
timer
any one of these units can be faulty
Oct 10, 2009 | Kenmore Dryers
Kenmore Dryer won't heat up
thermal fuse is bad. replace fuse. clean out vent duct. thermal fuse usually blows when there is restricted air flow over heating element.
Jun 24, 2009 | Dryers
Where do I find the heating element in a Kenmore 70 series dryer model 110.96575100
the part number you will need is 279838 and you can get that at whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore Dryers
Kenmore series 70 electric dryer will not heat up, but will rotate.
remove the back cover and check the heater box fuse and the heating element,do you have a meter?
May 10, 2009 | Dryers
Kenmore 110.66712690 66712 ser.#mf3411314 not heating
ck the thermo fuse on the lint duck inside dryer its the white one also ck the thermo fuse on the element housing the one near the back dryer
Mar 06, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
647 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
