Question about JVC Audio Players & Recorders
My jvc rc-x240 will not play a cd. The turntable spins around but not music. The top of the inside lid as a round disc that probably makes the connection to plya? I never noticed before but it is quite loose an wobbily, I don't now if that is the way it should be or should it be tightened. It tried but nothing seems to tighten it. Please help, Karen
  • 97 Answers
SOURCE: Cannot play or eject disc
Loading gear jam or broken loading motor belt. Disasemble unit to remove disc and check operation of motor and gear assembly. Repost the results so we can better help.
Posted on Jun 11, 2007
worldvet
  • 859 Answers
SOURCE: JVC CD portable system RC-X270/X260
Sorry to tell you that these players are famous for coming out of the factory with wire leads broken from their mounts.
You will have to dig into the guts of your player and find the loose wiring and resolder it in place.
If you don't feel qualified to do this perhaps you know a friend or neighbor that can. Lacking that a repair shop will fix it for you. But, you have to decide if the cost of repair outweighs the cost of replacing your portable player.
Sorry to bear this bad news to you.
Regards,
Worldvet
Posted on Jun 15, 2008
Pyrhyc
  • 2028 Answers
SOURCE: HP Pavillion not reading audio CD
It is possible that this is a drive issue, I've seen drives that one of the optical reader device has gone out, but generally it'e the DVD reader and will only read CD's. It's very rare that the CD reader goes and the DVD reader works. Before you replace drive, if it's only music CD's (you didn't mention program CD's), then update your media player. If it still won't play, then unistall the media player and completely reload it. At this point you can replacse the drive.
Posted on Jun 28, 2008
tiway1
  • 100 Answers
SOURCE: Glass plate turntable won't spin any more
no microwave 1.5 yrs old has a belt - they're all motor driven
Posted on Jun 30, 2008
tech48
  • 624 Answers
SOURCE: Hi. Own A Kenwood RXD
It is the laser, If the cd mech is in the top of this one you may just need to clean the lens manually. Cleaning discs are not all that reliable. You can do this by taking the top off and looking at the area where the disc gets clamped to play. The laser has the small glass lens. That is the part you need to clean. Take a Q-tip and wet it very lightly with some windex or some alcohol. Make it so that the Q-tip is just barely wet. Then just lightly rub the lens without pushing on it hard at all. Just nice and easy over the glass lens. Then dyr it off with the dry end just like you did with the wet end. That's it. close it back up again and turn it on and see if it plays. If it still does not play you need a new laser. No other fix for it.
Posted on Jul 03, 2008
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
I've realized that the jvc rc-bx30 can't read mp3 files. I would like to burn music to a cd/dvd and then play it on my jvc. What format should i use? By the way is there a possibility to change the reader...
Indeed the JVC RC-BX30 is a model of 1999, too old to be able to read mp3 cd. As you said you can write the mp3s to audio cd and then play them from this Boombox. You have to use the typical "audio disk" format (16bit, stereo, 44.100Hz). This format is available at any recorder software (Nero for 50Euros, or Ashampoo for free or anything else you have in your mind). There is no possibility to change the cd reader in order to be able the JVC to read the mp3 cd.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 13, 2011 | JVC RC-BX30 Cassette/CD Boombox
Sony cfd-z110 cd seems to not spin/play when door/lid is closed but will play when lid is open and lid switch is depressed, is there any thing (maintence) that needs done on that round piece (that is...
your on the right track. the piece on top should spin really freely. there is a spring inside of that piece. if it lost its track it will lock it up from spinning. one other think it maybe is the tab is broken that presses the switch down. inspect both things if it ends up being the tab missing you can simple hot glue the switch down or dissemble and twists the two wires together (ones at the switch) that will bypass the switch. beware if you do this the laser will be active every time you have it in cd mode. (don't look at the laser it can harm your eyes) hope this helps please rate me.
Dec 31, 2010 | Sony ZS-S2IP Radio Boombox
I have a JVC RC-ST1, I'm trying to record from CD
check to make sure the tab on the cassette is not on, as if it is, it will prevent the record button from being pushed down , thus avoiding overwriting the cassette.
If thats not the case then the record mechanism is damaged inside the cassette caddy.
May 19, 2010 | JVC RC-ST1 Cassette/CD Boombox
Cd turntable does not turn without jarring the whole unit - therefore, cd's do not play
Sounds like the little motor inside the cd turntable keeps sticking, i have seen electronic motor do that from time to time, it might be worth having a go at pinching the side around the motor to try to loosen it a bit or completly changing it out.
Jan 16, 2010 | Audio Players & Recorders
My ford mondeo 6X CD Sony is playing up all the time with original c.d's Can you help showing change cd check cd then suddenly works Do i need a c.d. cleaner?
The problem maybe that the drive gear that spins the disc is sticky. I had same problem, take cd unti out remove front facia then remove cradle that locks cd into dash. This give access to 4 screws, remove top lid on cd and temp connect facia and cd back in car load cd and watch to see if it spins up if not spin gently with finger. If it plays ok remove and gently oil between black drive disc and motor. Play cd again hopefully this will resolve problem.
Make sure laser is clean of any oil that may have spun off disc.
Best of luck it worked for me.
Apr 20, 2009 | Sony Audio Players & Recorders
CD Player Problems
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Aug 17, 2008 | JVC MX-KC58 Shelf System
Cant play
Not a solution as much as clues. I was given a SL PD588 by a friend 'cuz it stopped working. When I got around to checking it out it worked fine. Later it quit. It would rotate the turntable, load up a disc when you hit play, try to play the disc, fail, go to the next disc, etc. I pulled the cover, watched it try, could hear the lens seeking focus but the spindle wouldn't kick in and rotate. After cleaning the lens with no luck, my teenage observer decided he would spin the disc himself and maybe faster would help. Damn, if it didn't work. Sort of reminding the unit what it was supposed to do. However, not a permanent fix, 'cuz periodically it would forget and quit again. I would repeat the drill, basically giving it an assist to rotate the disc (clockwise), (maybe a few times) and it would be back functioning.
I have found the problem occurs if I leave the unit on too long, (especially in pause mode ie disc spinning, for a day or two). So I now power off when I'm thru playing discs.
Just went thru the drill again today, cover off, a little nudge to the spindle top when the disc loaded and back in business. Came to FixYa to see if anybody had an answer.
BTW, you can tell if the disc is playing correctly just by watching the track clock on the display.
Too bad the unit is so big 'cuz that means one is always stacking stuff on top of it.
Finally, and it's not like I haven't entirely dismantled this thing looking for an answer. Inside my unit is my long note on how to disassemble the mechanism.
Dec 23, 2007 | Technics SL-PD887 5-Disc CD Changer
Playing the cd's produced on my jvc stereo system
If you took the same steps, then obviously, it should work the same. However, there are many factors that could cause it to not play. You can try a different CD-R burning program. Also, some stand alone CD players do not play CDR's. So make sure your CD player can handle this. Also make sure your not burning an MP3 CD or similar. Make sure you also close the disc when it is done, and leave a 2 second gap between each song. Lastly, try burning at a slower speed - such as 4x - believe it or not, burning at a higher speed does affect your CD's playing options, especially on older CD players. Hope this helps! - Justin DJPROAUDIO
Jun 07, 2007 | Crosley CR248 Turntable
50 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
