Question about Canon NP 6035 Copier
Cannon NP6035 The copier doesn't respond when buttons are pressed. It just sits there laughing at us.
  • JS_KO Sep 15, 2008
    The copier is ready to copy but pressing the copy button means nothing to the copier
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
That's a good one. LOLOLOLOL !!!!
what mode is it stuck in ? does it say warming up ? if yes, then the problem is w/ the fuser ( exit where it gets hot) there is a temperature regulator ( thermister) it may be going bad.
Posted on Jul 17, 2008
Cannon i865. Operator Error message and blinking orange light (5 blinks). Switching off power does not reset. Also used reset technique from this site, this does not seem to work. Any more ideas?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 23, 2011 | Canon Office Equipment & Supplies
I have a Cannon i560 printer and the light on printer flashes five times orange then flashes green, what is the problem and how can I fix it.
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
May 18, 2011 | Canon BubbleJet i560 InkJet Printer
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
Photocopier machine canon np6035.it is has no user manual
Try justmanuals.com.They have operators manuals for about every copier ever made.They are a pay site.I know of no free sites.Good luck
Mar 31, 2009 | Canon NP 6035 Copier
Cannon pixma ip1700 not printing
1. Turn off printer
Feb 13, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon NP 6035
2 things will cause this.
1 is a problem with the scanner: brokenn cable, dirty rails, dirty or faulty sensor, faulty scan motor or motor driver.
The second is much simpler. A stuck key on the keypad will lock the machine. Press every button on the panel to make sure each one makes the usual click sound as it is pressed. Sometimes just pressing the keys will cause it to become unstuck, other times the keyboard must be disassembled to remove the crumb, dirt, debris, etc, interfering with the key.
Sep 18, 2008 | Office Equipment & Supplies
Cannon NP6035
check here for the code: just look for the code, doesn't matter what machine type, they use the same code for different types of models
http://www.copier-help.com/copier-help/ecs/canon/eccgp200.html
Jul 23, 2008 | Canon NP 6035 Copier
Cannon np6035
sounds like a bad control panel. Unfortunately I've had to replace quite a few of those when I use to work for Canon on those models.
Try this, press really ******* any key see it changes.Not sure if you are tech oriented but you can remove the panel and get to the main board ( a lot of tiny screws) but not hat hard, once you get to the board you can push the buttons on it and see if it changes.
Jul 17, 2008 | Canon NP 6035 Copier
Cannon NP 6035
probably the buttons are not working. you will need to check the control panel (whee the button are at) and check if the micro switches are working properly.
I have a Pixma ip6000d. Doesn't function except for the power lamp.Is there a reset or any thing I can check out.
You could try this reset procedure;
1. Turn off printer
I use it on my IP3000 to reset and it is meant to be for ALL Canon pixma ip 3000 and above, best of luck!!
Jul 04, 2008 | Cannon Office Equipment & Supplies
Canon NP 6035 Copier Logo
59 people viewed this question
old marine
old marine
