Question about D-Link DP 300U (DP-300U) Print Server
DP-300U revB and KONICA MINOLTA bizhub 163
Hello, i have d-link print server dp-300u rev B and we today got new printer+copier konica-minolta bizhub 163. Printer has an usb conection. Then i conect it to print server, print server writes printer status:paper out and printer doesnt print. Pls help to solve this problem as soon as posible. I think its becourse of firmaware (now upgraded to 2.10). If anyone has any ideas whould be great and if u can pls write me to e-mail andrius@limita.lt
Thanx
  • 6 more comments
  • szabcsi Jul 22, 2008
    I have a DP-301U, HW rev B2, Firmware 2.20, same problem...
  • masacramento Aug 20, 2008
    Same problem her with conceptronic print server.
    I belive that it's made by minolta to sell network printers or something like that.
  • andrius27 Sep 16, 2008
    we solved this problem by buying a new print server :/ D-link DPR-1061. on that dpr works fine (including scaner)
  • Anonymous Nov 26, 2008
    Same than you...
    Konica minolta Bizhub 163 and D-link Dp 301U
    Printer status: paper out.
    Upgrading the firmware doesn´t fix the problem.
  • Anonymous Nov 27, 2008
    Hi. I also have KM Bizhub 163 and it is connected to print server D-Link DPR-1061. The printer status is paper out. The printer won`t print.
    What do I have to do to make the printer work throw the network?
    NickJ
  • the NickJ Nov 27, 2008
    of course :) through the network not throw
  • Anonymous Feb 19, 2009
    Same problem with Canyon print server!
  • Anonymous Apr 29, 2009
    printer status: paper out
I have just setup DP-300U rev.B1 with my Konica Minolta Bizhub 162, the thing is that it doesn't work with USB port connected (paper out), then I tried connecting Bizhub 162 to LPT port, and it works just fine...
Posted on Aug 25, 2009
Change print server with surecom brand
Posted on Nov 10, 2008
I have some problem :(
Posted on Sep 16, 2008
Can't find my usb Printer on my D-Link DP 300U (DP-300U) Print Server What to do anyone
ok have you tried changing the settings in the print server usually a printer must be configured on the print server before it can be used if it is on the network try telneting in to it through a web browser like you may a modem
Oct 13, 2011 | D-Link DP 300U (DP-300U) Print Server
I want to update the firmware on my d-link dp300u print server to version 2.2, how do I do it?
Your type of d-link the highest version is 1.20 which can be downloaded from ftp://ftp.dlink.com/Printserver/dp300U/Firmware/dp300u_firmware_120.bin and updated on your d-link administrator page.
Jul 17, 2010 | D-Link DP 300U (DP-300U) Print Server
DP 300U
DP 300U's can get be pretty uncooperative when attached to a different router. One solution is to reset the DP 300U to its factory settings. Use the PS Admin software to do this. (If you lost the PS Admin software, you should be able to download it from the internet.) If the software prompts you for a password and you do not know it, try "SYSXXXX", where XXXX is the last four digits of the MAC address located on the underside of the print server.
After you reset the DP 300U you will need to set it up from scratch, a process which is not particularly intuitive. Refer to your "Quick Install Guide" (download it from D-link's web site if you don't have it anymore).
Oct 17, 2008 | D-Link DP 300U (DP-300U) Print Server
Having to reset (unplug) daily
Check the Printer spool service. If documents are getting increase in que, restart the Printer spool services. It will definatly solve your problem.
Oct 03, 2008 | D-Link DP 300U (DP-300U) Print Server
Configuring a Mac Book Pro laptop with a DP 300U Print Server
I connected my HP5MP to the DP-300U LPT1 port.
I configured my port on the DLink Configuration tab, giving it a name "hp5"
...The default login is at http://192.168.0.10/ user:admin pass:(there is no pass by default)
On my Mac, I go to System Preferences > Print & Fax
Click the + to add a new printer
Select the IP option
Choose the Protocol: Line Printer Daemon - LPD
Type in the Address: 192.168.0.10
Type in the Queue: hp5
Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...'
and find the driver for your HP LaserJet 5MP.
Save it. Works like magic. ;-)
If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
Sep 07, 2008 | D-Link DP 300U (DP-300U) Print Server
To install hP psc 1315 on the D-link dp-300u
You might try to browse to that disk and see if there are any setup files (usually named setup.exe or install.exe). I've seen some drivers don't need to be installed by an installation program not by the new hardware wizard.
Feb 08, 2008 | D-Link DP 300U (DP-300U) Print Server
D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Jan 27, 2008 | Sharp AR-5320 Black and White Copier
D-Link DP 300U (DP-300U) Print Server Logo
3,803 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
