Question about Canon NP 6035 Copier
Cannon NP 6035
It doesn't respond to anything. When I push the copy/start button it doesn't react. It just sits there
  • jempergirl Jul 18, 2008
    Thank all of you for your help. The last suggestion worked. The keys were stuck. How elementary. We have four offices and everyone knows now to hop on to fixya for help. Thanks again.
  • csimins Oct 09, 2008
    Error E212 turn off and turn on
  • 62 Answers
Probably the buttons are not working. you will need to check the control panel (whee the button are at) and check if the micro switches are working properly.
Posted on Jan 22, 2009
Send your email adress!
But I think that the best way is to buy new one digital age.Its not worthed to waste your time on this machine.
In service manual wont find nothing abaout your problem description.
Check dc controller, power supply, check fixing assy...
Jun 22, 2010 | Canon NP 6035 Copier
How do you replace toner for canon np 6035 copier
open the front cover, then you will need to slide out the piece the toner goes into, upper right side. Set the toner cartridge on top. You will see a tab to pull toward you, so the toner will drop down into the copier. Push the tab back in. Then push the cartridge toward the back of the copier a little and pull up.
May 15, 2010 | Canon NP 6035 Copier
Cannon 6035 - no immage on copy pages
Are you getting a totally blank copy or just very light. If I were you I would cheak to see that the developer Lock is in the right place. It seats right under the developping unit. It should be locked to the Left. It will move the developing unit closer to the Drum unit..Good Luck
Apr 13, 2009 | Canon NP 6035 Copier
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
Apr 03, 2009 | Canon NP 6551 Black and White Copier
Copier Drum problem
If you send me a copy i 'd tell you
Mar 20, 2009 | Canon NP 6035 Copier
Cannon NP 6035
2 things will cause this.
1 is a problem with the scanner: brokenn cable, dirty rails, dirty or faulty sensor, faulty scan motor or motor driver.
The second is much simpler. A stuck key on the keypad will lock the machine. Press every button on the panel to make sure each one makes the usual click sound as it is pressed. Sometimes just pressing the keys will cause it to become unstuck, other times the keyboard must be disassembled to remove the crumb, dirt, debris, etc, interfering with the key.
Sep 18, 2008 | Office Equipment & Supplies
Cannon np6035
sounds like a bad control panel. Unfortunately I've had to replace quite a few of those when I use to work for Canon on those models.
Try this, press really ******* any key see it changes.Not sure if you are tech oriented but you can remove the panel and get to the main board ( a lot of tiny screws) but not hat hard, once you get to the board you can push the buttons on it and see if it changes.
Jul 17, 2008 | Canon NP 6035 Copier
Cannon NP6035
That's a good one. LOLOLOLOL !!!!
what mode is it stuck in ? does it say warming up ? if yes, then the problem is w/ the fuser ( exit where it gets hot) there is a temperature regulator ( thermister) it may be going bad.
Printing on Canon NP 6035
I check and couldn't find anything that came close to that model number. You should contact them directly. It may require a copier dealer in your area to get one for you.
Jun 26, 2008 | Canon NP 6035 Copier
Canon NP 6035 Copier Logo
99 people viewed this question
old marine
old marine
