Question about Disney Mix Max Digital Media Player
The earphone port has lost whatever holds the earphone in the mix max, can it be repaired?
    Sergeant:
    Champion:
  • 417 Answers
Yes it can be repaired your looking at $20 for new headphone jack installed should not cost anymore than that any electric repair place should install one for you even radio shack
Posted on Jul 17, 2008
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
I lost my cd to down load software to my laptop
Please check the following links for help:
www.playdigitalblue.com/customer-service/faqs/???disney/???mixmax
www.bestvistadownloads.com/???download-disney-mix-max-player-software.html
Sep 27, 2010 | Disney Mix Max Digital Media Player
I have a disney mix it and I can't unlock it
On the top of the Disney Mix Max, the fourth button on the left which says "< HOLD", slide it to the right and that should unlock it. :D
Sep 11, 2010 | Disney Mix Max Digital Media Player
My mix max volume is all the way to its max but it still sounds very low
I had the same problem with standard over the head earphones, however, when I used it with earbuds, the volume increased tremendously and we now have no problems with the volume sounding too low. My daughter has a hard time with regular earbuds, so I purchased some "clip" style earbuds.
Jan 07, 2010 | Disney Mix Max Digital Media Player
How to charge the mix max
You can use a phone charger that has the right connection or a cable connected to your computer's USB port
Nov 26, 2009 | Disney Mix Max Digital Media Player
No earphones sound OK, with earphones no sound
the connector may have come loose from the player board, you could try opening it and replacing/resoldering the port, but it would be best if you just sent it back for repair.
Nov 05, 2009 | Sumvision ICE800 Digital Media Player
I lost my disney mix max charger
There are several types of chargers you can use with the mix max....car charger, wall charger, USB to computer (FYI turn your computer off while charging and it stops), and my favorite - the speaker station. Just do a search for disney mix max charger on the internet, amazon, or ebay and several options will come up. I like the speaker station because it is easy to charge with it and lets my daughter use it as a stereo and dance unit if she wants.
Dec 10, 2008 | Disney Mix Max Digital Media Player
How do i get videos on my mix max?
here it is, for those who nearly threw out those little things away, im not a techie but after 2 days i finally figured it out. whew! my 2 girls love youtube and music videos so for those who wants to get and play them instead of movies (the batteries on the mix max are not so good anyways) this is step by step, so be patient.
1. download youtube downloader (i usually download at cnet or sites you trust) to get those flv videos you like. (its quite easy to use and its free!!!)
2. download stoik video converter-(its free too) to convert those flv files to WMA, its quite easy to navigate but remember on the OUTPUT FORMAT choose wmv, i used WMV for ISDN 128, but...STILL in the output format click "edit profile" (scroll down to the end and you will see it) another window will pop out and change the frame size to 192x144 (mandymmof2 was right theconverted frame size should be at least the same size or smaller so thanks to him i was able to solve it)
3. go to windows media player or you can just open your converted video. drag it to the sync list, (but make sure your mix max is already connected and it says create a list to sync to mix max storage (internal/external whatever memory you choose to use)
remove and play...
FOR THOSE WHO DONT KNOW HOW TO DELETE SONGS/VIDEOS/FILES FROM MIX MAX .
you can delete it by clicking my computer, click disney mix max drive... the files you uploaded are all there to delete.
hope this helps!!
Jan 18, 2008 | Disney Mix Max Digital Media Player
Device won't recharge
My player also ran out of power and won't recharge. I e-mailed digital blue through their website (www.playdigitalblue.com). They answered right away and suggested solutions. I tried them all but none worked so they asked for my purchase receipt and have me send the player for testing or repair. They might replace it if it's defective.
Jan 06, 2008 | Disney Mix Max Digital Media Player
I can only hear out of one ear of my ear phones and sometimes I hear no sound at all
Perhaps you can open the player and solder the head socket it may have some dry joints there.
Jul 24, 2006 | Dell Pocket DJ MP3 Player
Disney Mix Max Digital Media Player Logo
41 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
