Question about Dell Inspiron 5100 Laptop
Booting up dell inspiron
Good morning,
I am having problems turning on my laptop. It states, "No bootable devices. Strike F1 to retry boot; F2 for setup utility.
Please advice on what can be done to do a quick fix.
Many thanks,
Diane Vargas
512-775-9926
fsnbiz@yahoo.com
    New Friend:
  • 9 Answers
Why are we still seeing problems from 5 years ago? And why are people commenting on them when the person with the problem has probably been through 3 laptops since then?
Posted on Sep 25, 2013
Hi diane
this happened to me i had to replace the hard drive .now i am struggling with reloading operating system
Posted on May 24, 2013
Maybe download linux ubuntu and run os from the cd and see if it works if it does then you need to buy a new hard drive
Posted on Feb 02, 2012
    Sergeant:
  • 313 Answers
With no bootable devices, there is no quick fix. It sounds like your hard drive has died on you. Best to buy a new hard drive and re-load.
Posted on Jul 17, 2008
Hello mi problem is wen i turn on mi lapton dell ispiron 2200 apear no bootable devices strike f1 to retry boot, f2 for set up utility, wath i can do? windows xp
Your hard drive's Master Boot Record might be the problem. If it was corrupted then the bios will not see a bootable hard drive.
Three things you have to do in order to solve this.
1. purchase a 2.5" external enclosure, remove the hard drive and put it in there.
2. purchase another 2.5" hard drive for the laptop and reinstall Windows.
3. once the reinstall is done, plug the enclosure into the laptop by the usb cable and copy your data to the new hard drive.
Sep 25, 2011 | Dell Inspiron 2200 Notebook
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Oct 27, 2009 | Dell Inspiron 1521 Laptop
My dell inspiron b130. says no bootable devices and strike f1 to retry boot. f2 for setup utility. but nothing happens just repeats sentence over and over
It may be that your hard disk is shot - or its connectors may have come loose or slightly corroded. Remove the hard disk and then reseat it back again. Good luck.
Sep 28, 2009 | Dell Inspiron B130 Notebook
Ispiron 4000 wont boot up
Your Hard Drive Needs to be Replaced
Jan 10, 2009 | Dell Inspiron 4000 Notebook
Hi and welcome to FixYa,
Offhand, this error message is indicative tht the CMOS/BIOS could no longer detect, recognize, access and use the internal hard drive of the laptop. Sorry to be bringing you the bad news.
Corrective solution wold be to replace the HD, perform a clean/fresh install of your Operating System. In some models, there are recovery Cs that would facilitate the process. In the absence of such, an OEM Windows CD installer would serve the same purpose even if borrowed and the CD key printed on the sticker underneath the laptop be used.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate it at all. Cheers.
Dec 27, 2008 | Dell Inspiron 1501 Notebook
Dell latitude C610
From the Bios, load all the default settings and then check the bios SATA port settings. If it is set to AHCI, change it to IDE to boot from Hard Drive. This should solve the problem
Oct 01, 2008 | Dell Latitude D600 Notebook
Windows will not start
try reseating the hard drive. Unscrew two screws on bottom right of laptop, where it IR window is. Slide the cover down, then out. Make sure the bottom connector is flush, then slide it back in
Jun 17, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Dell Inspiron 5100 Laptop Logo
310 people viewed this question
Alun Cox
