Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Same Local Disk issue on WD External Hardrive, Please Help
Hey there, im running testdisk, but im afraid of doing something wrong, can you guide me through, my email is coybruniclark@hotmail.com
as of right now after hitting "Analize" i see my hard drive and it even says My Book, below that it says
Bad Sector Count.
No Partition is bootable
i was wondering what to do next. and then after that what to do next
i appreciate your help.
Coy
  • 101 Answers
Scan your files virus is infected so please scan fiels than it will work means remove the bad sectors
Posted on Jul 23, 2008
My desktop hardrive (C) is running out of memory. I've attached an exterior hardrive (E) to the computer with lots of available memory. However, I'm still getting a message that I'm running out of...
Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2)Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on Viwe Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you ee inside Temp Folder
5)Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you eill have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC and your issue will be resolved.
If you feel that my answer has helped you in any way then please give a vote.
Thanks.
Apr 07, 2011 | IBM Computers & Internet
So my terabyte (external) is showing as a local disk hen i explore...it is saying "corrupt or unreadable" and when i go to properties it is showing all 0 of 0 is used...am i stuck?
Hello Pmtarq, hi, there are two possible bad part, first your hard drive is really bad, you need to reformat your drive, all data will be lost. (this is the common solution) or second the device electronics is bad, you can not do anything if the device fails, all you can do is salvage the hard drive. (this is a long shot, but possible)
Apr 09, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Same WD Passport problem as By sowhatbks on Oct 06, 2009
I'm afraid your data is most likely gone. The drive volume label "My Book" is not there because the partition is corrupt or it was deleted. You can try to recover the data with a bootable disk utility but this seldom works. I would delete the partition, run a WD utility to check the disk, (You can download it from WD web site) Then, if the disk tests ok, create a new partition and format it.
Oct 16, 2009 | Western Digital 250GB MyBook External USB...
1tb WD external hardrive not mounting, can't access my info ?
First of all, restoring a hard drive rarely affects data stored on it. I usually just adjusts the supporting software that allows it to run properly. Definately check the manual prior to restoring it, though. Formatting it will absolutely erase everything (unless your the FBI). I'm about 99% sure that restoring it will leave your stored data completely unaffected.
You're better off performing the work using the newest OS available. BTW, your BF can plug into the internet and get upgraded to 10.4.11 as well for free and it doesn't take long.
Oct 06, 2009 | Western Digital My Book Essential 1TB...
Western digital wd 500gb external hard drive not showing the icon
Doewnload Testdisk and run it to see if it can find a boot sector.
Oct 04, 2017 | Western Digital 500GB My Book World...
Hardrive issues
hi, remove and put the hard disk in another machine where you disconnect the cd rom and fix the hard disk so as to view two drive(c(hard disk in the machine)&e(the faulty hard disk))open c and create a folder ,open e and copy your files to c .
after remove the e drive and fix it to its machine.
format the hard disk then copy the files in c(in the other machine)using the above procedure
May 21, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Book Essential Edition showing as Local Disk
Then how about an explanation?
What most likely happened (and Windows has a bad habit of doing this...) is that the partition tables on your hard drive were deleted.  Either by an error in Windows or by some other application that is running.
Otherwise... It could have also been caused by not using the "Safely Unplug Hardware" function in Windows.
That's right.  That little icon that you normally ignore about plugging and unplugging USB devices?  You REALLY need to pay attention to it when it comes to data storage devices.  I myself have had this very same issue occur with my external drive.  It happened to me a couple times this month in fact.
I took my drive and disconnected it from my Windows machine and plugged it into my Linux machine.  I couldn't mount it.  Linux informed me via the console that I was using that it was most likely due to being unplugged from a Windows machine without using the proper method.
The dismount of the drive in Windows was inconsistent and unclean.  I actually lost the partition table.  Not a big deal.  I recovered the data easily enough...
I then re-tested this 3 times.  Each time, Linux refused to mount the drive until I plugged it back into the Windows machine, run a disk check on it and then PROPERLY disconnect the drive.
Each time I did it properly, Linux mounted the drive without any fuss.  (I believe that this message is a function of the ntfs-3g package.  The one that lets you read AND write to NTFS partitions in Linux.  I've never had an issue with it before I started using that package.  Very nice.)
So don't ignore that little icon in the future.  It really does make a difference.
Cyryl
Oct 31, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
170 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
