Question about HP Computers & Internet
Have a broken hinge pin on dv9500 hp laptop. have replacement part, need schematic on removal of broken pin.
  • 313 Answers
Yes you can.
These WEB sites shows how.
Replacing a hinge, or both of them, isn't very tough. Replacing Display hinges
Dec 07, 2012 | HP Mini 2140 Notebook
You can purchase the display hinges for the notebook from any local computer parts reseller. For your convenience, I am providing you the part number of the display hinge compatible to your notebook. Please note that the display hinges, hinge covers, hinge screw caps, and display bumpers are included in the Miscellaneous Plastics Kit.
Part number: 353393-001
If you are comfortable to disassemble the notebook and replace the parts, then you can refer the service manual provided below for information to remove and replace the display hinges of the notebook.
Refer page no: 147 to 150
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
However, if you experience any inconvenience while replacing the parts then I would recommend you to take the notebook to a nearest Computer Service Center. I hope the information provided would be helpful.
May 15, 2010 | HP Computers & Internet
Replacing hp dv9700 keyboard
Look for the screw marked with a keyboard icon and removed them then you should be able to remove and replace the keyboard. Not too hard. You can get the service manual from HP if needed.
Mar 09, 2010 | HP Laptop Keyboard for HP Compaq Pavilion...
HP dv9200 not charging battery
there could be a few problems but first off does it run on just the battery or does it always need power? if it always needs power then id take the covers off the bottom of the laptop and check the wires from the conector on the back of the laptop to the battery, and also try giving the pins where the laptop and battery conect the amount of times iv stripped a laptop down and found its a dirty pin is anoying
Sep 25, 2009 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Replace hinge on HP Pavilion dv9000 labtop
Check out this WEB site on how to replace a hinge on a laptop. It may not be exactly the same model as your laptop but the principles are the same, Click on this link :-
Sep 09, 2009 | HP Pavilion dv9000z Notebook
Hinges for top cover for HP officejet 6210- Q5820A
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
HP Dv9500 not charging battery
Sounds like the AC port is faulty, these can be a real pain to get hold of replacements and a complete nightmare to replace if you are not very experienced with a solder iron! my advice would be take it to your local computer centre to have the port replaced but expect to pay around £70. if you do attempt to do this yourself you will need solder wick to soak up the solder holding the port in, a very steady hand and time.
Jul 02, 2009 | HP Computers & Internet
Broken (cracked) right Hinge on HP nc 4000 and Dell D600 Laptops
You can get replacement parts for this laptop, however it can get expensive. At the end of the day, you can use a super glue that is safe to use around electrical parts, but you might be better off just using an external monitor if you don't need to carry your laptop around.
Jun 01, 2009 | HP Computers & Internet
Compaq Presario V4000 (v4118AP) right hinge broken
I had the same problem, they are very easy to fix, I did a search earliar and found some on the link below.
You do not need to dismantle to base, you have some star screws under the battary and one either side that loosens the small panel near the screen (where the power button is). The screen cover has screws under the plastic covers then just unclips, be gentle. after that it is self evident
Aug 06, 2008 | Compaq Presario V4000 Notebook
Computers & Internet Logo
66 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
