Question about Lenovo 3000 C200 Notebook
Usb problem USB device not recognized this type of massage comes from the startup menu when i connect my HP D1461 printer
  • 149 Answers
Install a driver, you can get one from driverguide.com and chose respectable operting system
Posted on Jul 17, 2008
Printer not being recognized by computer
Sir/Madam
1. Is the printer turned on?
Make sure the printer is turned on.
Make sure the power cord is securely plugged into the electrical outlet.
Test the power by plugging in the power cord of another electrical appliance to an electrical outlet and turn it on. If the power to the other electrical appliance comes on, the printer may be considered to be faulty.
If this product is recognized:
Close this page to return to the installation window.
If this product is not recognized:
Proceed to the next step.
2. Are your computer and the printer correctly connected?
Make sure the USB cable is securely connected to the printer and to your computer and check that the USB cable is not damaged nor badly crimped.
The printer will not be recognized during the driver installation if connected to a printer switch or the printer buffer. If this is the case, try to directly connect the printer to your computer using the USB cable.
If you are connecting the printer to your computer via a USB hub, connect the printer to the first-tier hub from your computer. If the printer driver is still not recognized on your computer, try to directly connect the printer to your computer without the USB hub.
If you are connecting the printer to your computer via a USB hub, make sure the USB hub device is recognized by your computer.
3. Does your computer provide USB or IEEE 1394 support?
If Still Your Problem Is not solved Then Click On Below URL
http://files.support.epson.com/htmldocs/r1800_/r1800_rf/dset_1.htm
Or
Still You have problem Then please Follow Us On HP Printer Support
Jan 08, 2014 | HP P4515n LaserJet Printer
Printer comes up as category: unknown
Disconnect the USB cable..
Open the device manager...
Plug in the USB cable
see if you get the entry USB Printing Support under the menu
Universal serial Bus
if you don't see it replace the USb cable and try
On the Menu click on VIEW >>> Show hidden devices >>> try to find the USB print support
or the printers entry...
if you see it in some other category install the softwares
through the CD or get the drivers online through HP.com/support
it will work
if that does not work install the generic drivers
I.e open Printers&Faxes(XP), Devices&Printers(7)
click on add a printer
install a local printer
select the port as USB port
and follow the instructions
it will definetley recognize your printer
Happy Printing.....
Mar 04, 2011 | HP Officejet 6300
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
Having trouble installing HP Photosmart All in One Printer. Model C5280. Near the end of installation it ask's for printer to be connected via USB cable. Msg comes up on screen 'USB Device not recognized'...
Dear Sir:
It seems that the printer has gone bad because when you get this message 'USB Device not recognized' it means that the usb device connected to the computer is defective however I would suggest you to connect this device to another computer and if you are getting the same error with the other computer.
Please contact hp support they should be able to help you with this.
Please feel free to get back to me If you need any further assistance.
Regards
Mohammed.
Mohammed.feroz.ali@gmail.com
Jul 19, 2008 | HP Computers & Internet
Problem with hp laser jet 1018
i need the windows xp driver
Jul 12, 2008 | HP LaserJet 1018 Printer
Hp laser jet 1018 problem
try to connect the usb of your printer at the back usb ports of your CPU. and try to scan your device.
or
Do as follows inst.
Unplug your printer usb on your system. then attach it back to your computer then power on your printer.
Do right click my computer>properties> in system properties select hardware> then, click the Device Manager> tab, then select your device on PORTS. then click the scan for hardware changes> to scan your device. this icon can be found above or click Action menu and select >scan for hardware changes.
then restart PC. Hope you can do it. And it will help you.
thanks.
Jun 04, 2008 | HP LaserJet 1018 Printer
Scanning into my computer
Try these steps.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : Hp Photosmart C7200)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
IF IT DOESNT WORKS THIS
1.Click start - >run then type "twain_32" click OK.
2.A window will open and click EDIT menu-> select all, then delete all the files and folders.
3.Click start - >run then type "services.msc" click OK.
4.Look for service called "HPZ PML Driver", Doubled click on it, check whether the "startup type" is "Automatic", if not changed it to automatic.Checked the "Service status" is "started".If not click on "start" button.Click Apply and OK.
5.Right click on "HPZ PML Driver" and click "Restart".Close the window.Click start - >run then type "%temp%" click OK.A window will open and click EDIT menu-> select all, then delete all the files and folders.If u cant delete them its ok, just close the window and go to step 6.
6.Disconnect the Printer USB cable, Insert the installation disk of your printer.If Installation wizard pops up, click on cancel/exit.
7.open My Computer, right click on your CD/DVD ROM Drive , then click "open".Look for folder called "UTIL" then look for folder called "CCC".There you will see a file that says "Uninstall_2". Double click on that file.
8.A run box will poppup, click OK, now you will see the command windows, hit enter the Driver that is necessary for comunication which are corrupted will be removed.
9.After that, restart the PC and Insert the Disk and install the printer.Connect the Printer USB only if the PC prompts you to connect.After installaton completes, check the scanner.
Regards
Riz
Apr 11, 2008 | HP Photosmart C6180 All-In-One InkJet...
USB Device Problem after installing new printer
did you get a fresh set of drivers when you got that new hp? try this link, and advise your success on this.
Mar 09, 2008 | HP Officejet Pro L7650 Printer
Lexmark p6350 all-in-one not working
I am guessing that you're using the New improved windows Vista. If so, you need disconnect the printer power and usb connection. then remove the current driver for the printer and down load the current driver @:http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:571:0:0
The soft ware will tell you when to install the printer
Dec 30, 2007 | Lexmark P6350 All-In-One InkJet Printer
Lenovo 3000 C200 Notebook Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
